Closed Thread
Old 03-18-2010, 08:14 PM   #1051
ol Curt
Junior Member
ol Curt's Avatar
Re: What did you do to your truck today?
I've been sanding and sanding and sanding on my hood to get the high build primer where I want it. Damn, these hoods are big and with a lot of nooks.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline
Old 03-18-2010, 11:05 PM   #1052
hb32
hb32's Avatar
Originally Posted by DWright View Post
i have an offy single quad intake. pm me if youre interested.
Check your pm
hb32 is offline
Old 03-19-2010, 02:45 AM   #1053
Vernski
Originally Posted by hb32 View Post
No it is a stock 230. Next I am in the market for a Holley 390 cfm carb and a Offenhauser single quad manifold to fix the Rochester stumble.
HB32 check out this web site about the Clifford hot water heated manifold...Vernski
http://prostores1.carrierzone.com/se...119/Categories
Vernski is offline
Old 03-19-2010, 09:25 AM   #1054
DPowers
One foot in front of the other
DPowers's Avatar
Man I know what you are talking about.....
DPowers is offline
Old 03-19-2010, 08:15 PM   #1055
daxloves
daxloves's Avatar
Rebuilt the starter today. Brushes were ground down to nubs
Went to get gas and it wouldnt start back up. thought the battery was toast but a diff battery showed otherwise.
Napa couldnt even find anything for a starter on a 305 v6. All they could find was stuff for a 305 v8. Finally a mechanic from the back came out and grabbed some brushed out of a box and said "Here's what ya need" No computer and parts book needed. If it wasnt for him the ladies at the counter woulda been tryin to sell me a whole starter for $90.00 that MIGHT be the rite one! The brushes only cost me $3.65
daxloves is offline
Old 03-19-2010, 09:33 PM   #1056
sshockr
[vent] Nothing cause mother nature is a tease. It's 60 and sunny at 2 this afternoon and by the time I get home at 5 it's 40 and breezy. Now it's sleeting sideways with predicted snowfalls of 2 inches over night. Supposed to be back to 60 when I go back to work on Monday. [vent off]
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already.
1995 Impala SS - LT1/T56 Combo. This is my 1st priority project.
sshockr is offline
Old 03-19-2010, 10:35 PM   #1057
sams60gmc
sams60gmc's Avatar
Put some air in my bags then dropped her to the ground. Its sitting on the lower control arms now. Can't wait til its Z'd
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 03-19-2010, 10:39 PM   #1058
sams60gmc
sams60gmc's Avatar
Originally Posted by shortbed70 View Post
I just did the same thing with my lowers for alot less then tubular ones and I did it myself.
Looks great! The tube was kind of hard to get in there. I should have went square aswell.
Old 03-21-2010, 04:39 AM   #1059
Bugeyev8
Bugeyev8's Avatar
I got the rear axle seals changed in my 62 and the rear brakes and cylinders and finished up my tail gate latches, look !! No Chains !!
Bugeyev8 is offline
Old 03-21-2010, 02:42 PM   #1060
Slow Build
Slow Build's Avatar
What did you use for your donor tailgate? I'm guessing 88-98 C1500 but want to be sure. I've been wanting to do the same thing. Looking good.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 03-21-2010, 03:28 PM   #1061
HOGDADDY
HOGDADDY's Avatar
I got the wiring harness out of the new (used) cab and put the new firewall pad in (what a pia) and loosely installed steering column and ready to put my harness in the new cab.
I was gonna try and use the new harness but it is different than mine and has other options I don't need plus I onlt got the inside part not the matching exterior harness.
I don't want any surprises later. I know my original harness is good so gonna use it.
HOGDADDY is offline
Old 03-21-2010, 03:51 PM   #1062
derider
derider's Avatar
Smile Re: What did you do to your truck today?
Nice work on the tail gate!
derider is offline
Old 03-21-2010, 04:00 PM   #1063
sams60gmc
sams60gmc's Avatar
oops... video below.
Old 03-21-2010, 04:01 PM   #1064
sams60gmc
sams60gmc's Avatar
Old 03-21-2010, 04:14 PM   #1065
protrash64
Resistance is Futile
protrash64's Avatar
Disturbed.........lookin' good Sam!!!!!!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline
Old 03-21-2010, 05:05 PM   #1066
sams60gmc
sams60gmc's Avatar
thanks bud
Old 03-21-2010, 08:10 PM   #1067
Bugeyev8
Bugeyev8's Avatar
the latches/cables are 1990 chevy S10. everything else I made
Bugeyev8 is offline
Old 03-21-2010, 08:11 PM   #1068
Bugeyev8
Bugeyev8's Avatar
Thanks !!
Bugeyev8 is offline
Old 03-21-2010, 09:03 PM   #1069
shortbed70
shortbed70's Avatar
Rear bags in and working.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 03-21-2010, 09:14 PM   #1070
creep
Registered Loser
creep's Avatar
Got some notches in.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline
Old 03-22-2010, 12:27 AM   #1071
64c20crewcab
64c20crewcab's Avatar
Got some base color (POR-15 Silver) on the new motor... Not much in the grand scheme of things but its progress...
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline
Old 03-22-2010, 12:31 AM   #1072
jonathan-m
Hey, progress is progress. I sat on my ass all day and watched it rain
I was hoping to get out and finish up painting my bed, but mother nature said no. This weeks project: find some new tires and rims (easier said than done), and get the damn thing painted.
Rockin' a '66 and loving every minute of it
jonathan-m is offline
Old 03-22-2010, 08:10 PM   #1073
60apache
60apache's Avatar
bought a cam picked up block and pistons from machine shop, bought some heads, finished front end, got wheels and tires in.
60apache is offline
Old 03-22-2010, 08:46 PM   #1074
Bazooka
Keepin it old school
Bazooka's Avatar
Test fitted the gauge panel
Bazooka is offline
Old 03-23-2010, 05:36 PM   #1075
jkb
Finished up the weekend project clean up! Finally dove into betty jean and removed the front clip and the 6 cyl and 3 spd trans. Maybe start my build page this weekend.
jkb is offline
Closed Thread
