Senoir Member
SWB Driveshaft question
Anybody know if the rear driveshaft is the same on a SWB 4WD for a auto trans and a manual trans?? Thanks
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: SWB Driveshaft question
bump
Assuming that both had the NP205 transfer case, yes they are the same. The 465/205 combo uses a long adapter that puts the t-case in the same position as the TH350/205. On edit, I think that the 3 speed manual with the 205 was also designed to the same length.
Tim Last edited by Blazer1970; 03-15-2010 at 06:07 AM. |
Senoir Member
Thanks!!
