Old 03-19-2010, 10:48 PM   #1
kev2809
low n' slo
kev2809's Avatar
Rattle can paint options?
im gonna be sanding down my control arms this week and was wondering what kind of rattle can paint can i lay down and have it last? im not lookin into getting por 15 or anything, just a nice looking, durable rattle can job (if this is possible lol). just a basic black color.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-19-2010, 11:14 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rattle can paint options?
Krylon 1613 semi flat black
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-20-2010, 12:04 AM   #3
72lb4x4
You might think about using a brush. Rattle cans lay down very little paint.
72lb4x4 is offline   Reply With Quote
Old 03-20-2010, 12:09 AM   #4
ShowSS12
ShowSS12's Avatar
I have seen thinned rustolum sprayed with a HVLP gun that looked badass...
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 03-20-2010, 12:13 AM   #5
fixit-p
fixit-p's Avatar
I dont know how rattle cans outside of cali compare to what we have () but I use high solids paint from Barnes distribution and it is awesome one coat coverage and durable http://www.barnesdistribution.com/pd...icals_1_10.pdf
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 03-20-2010, 04:03 AM   #6
LMDGUY
LMDGUY's Avatar
I have used VHT paints before, spray well and hold up
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 03-20-2010, 08:08 AM   #7
ShowSS12
ShowSS12's Avatar
Oh ya there is a VHT epoxy roll cage paint, (thats what it says on the can) thats is nice. Its says its perfect for bare metal.
Adam M
STX Designs
Old 03-20-2010, 09:38 AM   #8
Shane
Shane's Avatar
rustoleum industrial thinned with acetone ... about a 50-50 mixture. both are available at your nearest lowes or home depot.
Shane is offline   Reply With Quote
Old 03-21-2010, 09:17 PM   #9
coater
Powdercoat them.
coater is offline   Reply With Quote
Old 03-21-2010, 10:01 PM   #10
RanchFlyer
I am gonna second Shane and say Rustoleum Industrial. If you can't spray it in a gun. Lowes also has it in a rattlecan, I personally use both. Rattle cans for one or two pieces, paint gun for large products.
RanchFlyer is offline   Reply With Quote
Old 03-22-2010, 02:19 PM   #11
kev2809
low n' slo
kev2809's Avatar
well i went to lowes and i found this stuff...
its rustoleum hammered black, for rusted/slightly rusted areas. i think they came out looking clean, i just hope they hold up. i sprayed 2 coats. thinking about doing my drop spindles now...
-_--_--_ _________
Old 03-22-2010, 05:12 PM   #12
Shane
Shane's Avatar
you really need to smooth out those weld corners a bit more ...
Old 03-24-2010, 06:28 AM   #13
kev2809
low n' slo
kev2809's Avatar
the weld corners aren't really sharp..but I was thinking of putting a weather strip around the top just to be extra safe
-_--_--_ _________
Old 03-24-2010, 07:29 AM   #14
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Copy cat!!! I have thatton my front end and also looks killer on the wheels
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-24-2010, 07:32 AM   #15
Hottrucks
Hottrucks's Avatar
oh hey I was comparing our arms...you need to drill a hole on the inside of your cup in the corner so any water will drain and if you wanted to remove the rest of the stop just drill the welds it will pop right off
your going to love the free drop
Old 03-24-2010, 08:36 AM   #16
kev2809
low n' slo
kev2809's Avatar
lol. I wouldn't say it was exactly free. I paid 115 for the arms. good idea on the drain. hey what size cups are yours?
-_--_--_ _________
Old 03-24-2010, 08:51 AM   #17
Hottrucks
Hottrucks's Avatar
2 3/4"..... still a good deal....if your running stock tires (29" tall) it will put your tires VERY close to your inner fender support and your going to have to do something about your wheel wells..if you come up with something simple let me know..also a 2 1/2" c notch will give you a nice stance when your dumped with a 2" drop spindle you will lay X member..not sure how much your looking to drop it but the spindles will also allow you to run the bags and control arms more in the middle at ride height....I find I bttom out the LCA when driving around real low
on a side note check your tie rods at full dump they maybe really close or rubbing the frame..that being said you can run from stop to stop with the wheel at full dump for trolling parking lots....also if you need a shock check out the monroe 5752 ( I think) there from a 50 chsyler imperial they work well with this set up
Old 03-24-2010, 09:39 AM   #18
kev2809
low n' slo
kev2809's Avatar
thanks for the info..I pulled my fender wells out already. I plan on fabbin some up when I get around to it. lol
-_--_--_ _________
Old 03-24-2010, 10:03 AM   #19
Hottrucks
Hottrucks's Avatar
couldn't find the pic..another thing is if your running a sway bar your going to need to trim some off the ends or it will hit the bags aired out..here the rear P bar pic
