Old 03-22-2010, 03:10 PM   #1
builtchevystrong
lowering questions
why would is that the kits have the front end higher? what is the cheapest bust good lowering kit out there? what suspension do u have to use for a 3/4 drop.
builtchevystrong is offline   Reply With Quote
Old 03-22-2010, 07:00 PM   #2
LONGHAIR
Re: lowering questions
You have to be more specific about the truck. What year? 1/2 ton? 3/4 ton? etc.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-22-2010, 11:34 PM   #3
builtchevystrong
year is 85 and its a 1/2 ton
Old 03-22-2010, 11:39 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Most kit lower the rear more to get rid of the the factory rake.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-22-2010, 11:49 PM   #5
builtchevystrong
waht is that sorry dont really know a lot?
Old 03-23-2010, 12:15 AM   #6
SCOTI
SCOTI's Avatar
From the factory, the rear of the truck sits approx 2" higher vs. the front so that when loaded w/cargo, the rear of the truck doesn't squat excessively.
When lowering the ride height, most people want to remove the factory 2" stagger which is why drops are listed as 2/4 (2" front drop, 4" rear drop); 3/5; 4/6; 5/7, etc. . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-23-2010, 12:39 AM   #7
builtchevystrong
ok so i cant haul anything like a dirtbike or boat? cause i have both.
Old 03-23-2010, 09:57 AM   #8
SCOTI
SCOTI's Avatar
Yes, you can still carry a normal payload capacity; it will just require the proper set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-24-2010, 12:02 AM   #9
builtchevystrong
Waht is the proper set up?
Old 03-24-2010, 11:57 AM   #10
SCOTI
SCOTI's Avatar
There is no one correct answer. You just need to plan your drop w/not compromising payload capacity. I suggest air bags on the rear to be 100% able to set the ride height where you want it & still adjust for loads.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-24-2010, 01:53 PM   #11
builtchevystrong
can you give me a good site to find cheap air bags. and do i still need a suspension?
Old 03-24-2010, 05:32 PM   #12
SCOTI
SCOTI's Avatar
Ride Tech offers a rear 'kit' that has everything you need.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-25-2010, 03:17 AM   #13
builtchevystrong
thanks for all your help
Old 03-25-2010, 03:22 AM   #14
builtchevystrong
holy **** is there a cheaper route man
Old 03-25-2010, 09:52 AM   #15
SCOTI
SCOTI's Avatar
Their 'Cool-Ride' kits are not priced bad for getting simple, bolt-on stuff that a novice can install. What kit were you looking @ & what is your budget?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-25-2010, 03:45 PM   #16
tasian
tasian's Avatar
i've been looking into airbags for a while and i think im just going to go the cheap way and start slow im just going to start with putting something like
http://easystreetair.com/d2600dominator.aspx
in the front and and something in the back then just wait to get the rest
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 03-25-2010, 05:19 PM   #17
builtchevystrong
http://www.ridetech.com/shop/index.p...ures_hash=V179 looking at this holy crap even stage one is incredibly expensive. !!! my budget is what it would cost me to lower it with spring $1500
Old 03-25-2010, 05:20 PM   #18
builtchevystrong
that sounds good and more resonable but how do you install it and how much is the back
Old 03-25-2010, 05:31 PM   #19
builtchevystrong
http://www.bilsteinus.com/cart/index...id=1429&zenid= is this both fronts? thats a resonable price for shocks.
Old 03-25-2010, 05:34 PM   #20
builtchevystrong
http://www.offroad-engineering.com/kingshocks.html
which one oof these would i need with a lowering kit? those a a little more expensive than beilstein
