Anybody running a 5.5/7 drop on a 67-72?
Just finished building my 70 chevy swb about 6 months ago and like always I've decided to change it up a bit. Right now it has a 2.5/3 drop with 245/45/20 up front and 275/40/20 on the rear. That's the best estimate I have anyways since I heated the coils due to funds. Just ordered the cpp drop/tuck spindles and 3" coils for the front and 5" coils for the back. Still gotta order the 2" block kit for the rear too. Is anyone running a drop like that with a 28" tall tire or something close to it. I had the wheels built to tuck enough for clearance with a drop, but I'm thinking I'm going to have to go with a shorter tire. Just wondering if anybody else had any experience with the same issues. Or any other that I haven't thought of. This one was my first older build. All the others have been late models and bags. Thanks for looking. Any feedback or suggestions is appreciated.
Re: Anybody running a 5.5/7 drop on a 67-72?
The 245-45-20 is almost 29" tall (@ 28.68"). You're going to need to get something shorter. 245 or 255-40's would be about max w/o buzzing the inner fender wells.
Also, from those pics.... the back-spacing doesn't look very deep. What size wheels & back-spacing do you have?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-22-2010 at 10:03 PM. |
Tot Roddin'
Going to have to run a short tire on a 20 inorder to run them on a 5.5/7" drop; or have spot on BS on a custom set of wheels. I think they will hit either the fender or the inner fender.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Im running a 4.5/7 drop with a 245/40-20 and 295/40-20 tires. The front can be lowered a bit more to 5.5 with this set up but nothing taller on the tire.
Alright thanks. The fronts are 20x8 with 3 1/2 bs. Rears are 20x9.5 with 4 1/2 bs. Thought the front would probably be an issue. May have to roll the bedsides for the rear. Guess I'll just change the tires out. Be cheaper than buyin new wheels. Good lookin trucks guys. Thanks for the quick response.
#6 | |
Yeah I know what ya mean. I told you guys wrong earlier. It's a 5" bs on the rear and a 4.5 bs on the front. Least that's what's on the order form I have from when I bought them. Sorry bout that.
also the cpp spindles are supposed to give another 1/2" to each side up front.
vw guy & now c-10 guy
![]() Join Date: Sep 2008
I have a 5.5/7 drop on mine- but Im running 225/75/15 on 15x7 all 4 corners- so probably not much help to you...
Bet that looks good man. These trucks look good with the rally wheels. Your tires are pretty close to the same height as mine. Only thing that will get me is the width.
yeah, plus I have the regular 2.5" drop spindles, so my front track width is wider. Havent had the bed on yet (since suspension work) so I don't know exactly how it sits yet. Looks pretty good so far though! lol
well by seeing the front view of it right there it looks right at home on the ground. I like it. Post some pics when you get the bed on.
