Old 03-25-2010, 12:06 AM   #1
Daniellane
73 chevy
so my dad has a 73 chevy that he hardly drives anymore. its setting on 39.5 by 18.5 or 19 boggers. its a 6 lug 373 gears. i wanna restore it and make it a decent possible daily driver with at least double digits gas mileage without losing the lift or tires or buying heavier running gear? so maybe a switch of gears? what does the board think would be the best gear ratio to get? also thinking maybe later on down the road switching out the 383 stoker for a 6.0. so lend me your knowledge. also best place to get doors fenders and hood and cab parts online?
Daniellane is offline   Reply With Quote
Old 03-25-2010, 12:09 AM   #2
mongoose
mongoose's Avatar
Re: 73 chevy
auto or stick? do you drive on the highway?
mmm 3.73's seem kinda small for 40" tires...
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 03-25-2010, 12:09 AM   #3
Daniellane
Re: 73 chevy
bigger picture
Old 03-25-2010, 12:10 AM   #4
Daniellane
Re: 73 chevy
its a 4 speed with a granny gear. i will drive it on the highway once its done
Old 03-25-2010, 12:31 AM   #5
3QTRTONS
3QTRTONS's Avatar
Re: 73 chevy
That's a LOT OF TRUCK!!! Seems you are kinda at the minimum for what it is. I don't believe a 6.0 will get you any better mpg than that 383. Less fuel flow (smaller CFM carb) MIGHT increase the economy - but you really can't expect a RHINO to run on a Happy Meal.
Online is littered with '73 parts, new & used.....all depends on what your budget is. Being in GA, there has GOTTA be a bunch of part available locally.
1969 ES5500 B E A S T 1976 K20 Suburban
1983 C10 'farm truck' 1984 K10 Suburban
1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 03-25-2010, 12:38 AM   #6
USSkoval
Re: 73 chevy
Losing the Boggers for a set of MT type radials would probably make a bigger difference than anything else.
USSkoval is offline   Reply With Quote
Old 03-25-2010, 12:06 PM   #7
Daniellane
Re: 73 chevy
yeah im gonna keep the 383 for a while. i was thinking maybe about swapping the boggers out for some toyos or something of that nature and maybe 20 inch rims. im mainly looking for better fuel mileage though because 3 to 4 miles a gallon just isnt going to cut it ya know!
Old 03-25-2010, 12:13 PM   #8
bikes&bowties
bikes&bowties's Avatar
Re: 73 chevy
Quadrajet and keep your foot out of it (small primaries) if you put your foot in it, gas mileage is a loss... Tune it tune it tune it... 3mpg seems BAD... I know of big blocks with lower gearing and bigger tires that get 6ish... I second losing the boggers for a toyo MT or Mickey Thompson MTZ or CLAW tire... Also smaller wheels=better mileage.. biug wheels on these year 4x4 trucks almost always looks ugly... and gas mileage will suffer... but with 40's don expect better than 8 or 9 mpg... a 5.3 swap MIGHT get you into the double digits... I cant imagine a 6.0 getting double digits though. how bout 12 valve cummins.. a bit more expensive and you lose the Bowtie BUT 20mpg i common and you could roll coal
bikes&bowties is offline   Reply With Quote
Old 03-25-2010, 12:29 PM   #9
Daniellane
Re: 73 chevy
yeah. i didnt expect much with 40's thats why i was pondering the 37s. whats the average cost of swapping in a 12 valve? along with the transmission, trans case and such to make it all match
Old 03-25-2010, 12:54 PM   #10
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 73 chevy
You need bigger axles brother. 35" max tire for 1/2t axles(which you have). You have 40" tires, get some one tons axles. Dana 60 up front and a 14 bolt full float in the rear.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-25-2010, 01:07 PM   #11
bikes&bowties
Re: 73 chevy
you could probably do it for about 2500 maybe more maybe less.. I would look for a cheap donor truck....
he already said he didnt want that... its not my problem if he likes broken axle shafts then again he wants to street drive it.. which makes me think oh no itty bitty brakes
Old 03-25-2010, 01:21 PM   #12
Daniellane
Re: 73 chevy
i forget till today my pops has a set of 8 lug axles. how do you tell what the gears are? or what type it is like a dana 60? Im down for all ideas.
Old 03-25-2010, 02:03 PM   #13
jchav62
1962 C-10
jchav62's Avatar
Re: 73 chevy
Q-jet and less aggressive 36"-37" tires.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-25-2010, 04:14 PM   #14
Daniellane
Re: 73 chevy
alright no less than 37's though.
Old 03-26-2010, 12:44 AM   #15
spinem
haha, ford guys...
Re: 73 chevy
new set of wheel bearings will blow you freaknn mind
spinem is offline   Reply With Quote
Old 03-26-2010, 01:46 AM   #16
Chevy623
Chevy623's Avatar
Re: 73 chevy
I haven't laughed like that in a long time. Thank you lol.
Jesse.
Chevy623 is offline   Reply With Quote
Old 03-26-2010, 02:42 PM   #17
spinem
haha, ford guys...
Re: 73 chevy
yes,
yes,
yes,
yes listen to the man.
i agree /w/ everything you said...
in addition, change your gearing, maybe upgrade to a ford 9 while your at it??
(yes a ford 9 will rob 20+ hp just to turn it, but it will take anything dished at it)
also maybe your local junk yard has a decent 480le /w/ t case? (get that overdrive)
Im sure there is a timing problem/valve seal problem /w/ your motor. 3mpg is crazy.
I get 10mpg driving /w/ old people, 9mpg getth there quick, 5 on and off the 2ndaries.
so it dose matter how you drive.... staying off the 2ndaries??!!!
also, a nice 12v1998 cummins would do the trick like said before!!!
Old 03-26-2010, 03:48 PM   #18
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 73 chevy
Nice truck but yea I would defiantly look at changing you gears and putting less aggressive tires on there will make a huge difference. 3.73s are way small for those tires my friend. Tune that motor as well that should help keep your foot out of it as well!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-26-2010, 06:07 PM   #19
LONGHAIR
Re: 73 chevy
Lower gears will definately help, not only with mileage but in "general drivability" too.....but, it is "false economy" to spend the money to put the right gears into those 6-lug axles. S
Step up to the strength and better braking of 8 lug axles and you might even get better gearing in the mix....or at least have something worth investing the gear money into.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-27-2010, 12:10 AM   #20
Daniellane
Re: 73 chevy
alright. ill take those thoughts into comsideration. what you guys think about maybe getting those ss twenties off the new trucks and putting 37s on em? if i keep the 6 lug and get less agressive tires. also whats a good place online for new fenders and such?
