Old 03-25-2010, 01:46 PM   #1
neo297
Re: 2004 yukon xl tranny slipping
Originally Posted by clinebarger View Post
Wow, now this super fluid keeps transmissions from burning up?
His 3-4 clutch failure is not fluid related. Low fluid level maybe but not the type
If the transmission gets hot enough to break down dexron III its toast anyway I dont care what fluids in it.
my fluids are checked regularly and levels were good there was no warning of impending failure in regards to any slippage or shifting issues. I have had a slight noise that no one was able to isolate( wheel bearings, tire ballance/wear patterns were checked and tranny fluid replaced with a new tranny filter just in case and the fluid was red and not burnt then, that was 3- months ago there was no metal found in pan but no change in noise after) that noise was intermitent almost a harmonic that would increase in volume with acceleration and decrease with deceleration but was not there with coasting. Then one day it drove to work fine and upon start up and heading home 3-4 started slipping like hell. 1-2 and reverse work fine.
neo297 is offline   Reply With Quote
