![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I need some help identifying these parts
Re: I need some help identifying these parts
1--air cleaner spacer
2--air cleaner stove pipe 3,5,8--AC Brackets 9--power steering brackets 4,6--alternator brackets 7--starter brace
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Member #1049
I agree with Pickupman with the exception of #7..... it is a power steering adjuster bracket, (goes on the back of the pump)
![]() Join Date: Oct 2007
Here is a little more information:
1. Items 4 and 6 are the alternator brackets + the rod on the back side. Makes it a 3 piece set which is 72 Trucks only. Going rate is $75.00 to $125.00. I think I just paid $100.00 for mine. 2. Power steering pump with reservoir in good shape is $75.00...Looks like pulley is bent (very common) so that will effect price... 3. Power steering brackets I can't help you with but Ledzep had a great idea about putting that on EBAY under the Camaro/Chevelle 66 to 68 years...Those guys have a "thick" wallets. 4. Complete A/C brackets in great condition are $300.00. You are missing at least 2 pieces that I can see...(back bracket on intake and adjuster from that bracket). For what you have their maybe $150.00??? Just guessing. 5. #2 Heat riser tube...$60.00 to $100.00 depending on condition. 6. #1 Air Cleaner Spacer $20.00. Hope this gives you more ideas...Alan |
425hp409
![]() Join Date: Oct 2008
I would like to be first in line for the heat riser tube to the air cleaner
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
Thanks for all the help. Package is on classifieds. I will seperate after a week if no interest.
