Old 03-26-2010, 10:57 AM   #1
sdailey
The Few, The Proud
sdailey's Avatar
K10 Cab Mounts...need second opinion
I bought a complete cab mount kit (Counterpart #67-5001) a while back and I need a second opinion on where they mount. The kit didn't come with any instructions so instead of totally guessing at this I hope someone can confirm what I'm already thinking.
Looking at the attached picture, the mounts circled in red are for the rear of the cab and the blue circled mounts are for the front cab mounts?
If this is correct what are the other mounts (4) for? Core support maybe?
Also, do I use the metal sleeves in the front bushings?
Thanks for any help.
Shannon
sdailey is offline   Reply With Quote
Old 03-26-2010, 11:13 AM   #2
srhart71
Re: K10 Cab Mounts...need second opinion
That is what they are. Look at NOTE just above and left of red box.
srhart71 is offline   Reply With Quote
Old 03-26-2010, 11:16 AM   #3
sdailey
The Few, The Proud
sdailey's Avatar
That note is for a 2wd kit listed in the ad above the picture I attached.
Shannon
Old 03-26-2010, 01:45 PM   #4
Gene
Gene's Avatar
I have that same kit and had the same question, MSGROSS posted pics of his and although they are somewhat different, the ones you have circled in red go on the back of the cab. http://www.67-72chevytrucks.com/vboa...d.php?t=391397
Gene is offline   Reply With Quote
Old 03-26-2010, 01:47 PM   #5
sdailey
The Few, The Proud
sdailey's Avatar
What are your thoughts about the ones in blue? Are those the correct front mounts?
Shannon
Old 03-26-2010, 02:00 PM   #6
Gene
Gene's Avatar
I would say yes, according to his pics. I don't know why counterpart does'nt send instructions?
Old 03-26-2010, 02:10 PM   #7
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Gene.
Is it safe to guess that the other (4) mounts are for the radiator support then? Also, did you only get (2) bolts in your kit as well?
Shannon
Old 03-26-2010, 03:13 PM   #8
Gene
Gene's Avatar
Thanks Gene.
Yep, been trying to find out what size bolts I need for the radiator support and the front cab.
Old 03-26-2010, 03:23 PM   #9
sdailey
The Few, The Proud
sdailey's Avatar
I'm not sure about the core support bolts, but this is what I found out about the bolt sizes for the cab. The front cab mount bolts are 9/16-12 and the rear ones are 7/16-14. Hope this helps.
Shannon
Old 03-26-2010, 05:15 PM   #10
Gene
Gene's Avatar
Yep for sure that helps, my kit is just as yours and it only came with the 7/16 bolts. Thanks!
