Old 03-24-2010, 09:05 PM   #1
70RedBlurr
ART Arms and sway bar
So I have ART arms on my bagged 70 and trying to find a sway bar that will fit. I believe I have the newer version control arms from ART and those arms are also for 73-84 spindle. I came across several different posts by members in the search and came across belltech's sway bar, part #5404. Has anyone used this sway bar with success?
70RedBlurr is offline   Reply With Quote
Old 03-24-2010, 09:09 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: ART Arms and sway bar
If you have the later version of the Strong Arms, why not use the Ride Tech (ART) Musclebar kit?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-24-2010, 09:16 PM   #3
70RedBlurr
Because I don't have $400 to drop on a sway bar.
Old 03-24-2010, 09:27 PM   #4
kev2809
low n' slo
kev2809's Avatar
you got any pics of it laid out?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-24-2010, 10:34 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Contact Nate Porter at Portebuilt Street Rods.
(you can also PM him on here)
He sells an Addco sway bar for around $225-$250.
I think he can get a stock swaybar and the modified swaybar that fits his Dropmembers.
I have both the Addco and the RideTech StrongArm sway bar.
To me,... the RideTech version, just isn't worth the $400.
Keith
Convert to disc brakes.
Old 03-25-2010, 02:35 PM   #6
70RedBlurr
Kev2809 here are some pics of the truck laid out or with out air.
Old 03-25-2010, 09:51 PM   #7
Rochlow
I'm going to X2 on this... $400 for a swaybar and some end links?? I order an Addco sway bar from Nate also. Usually, if Nate doesn't have a solution to a problem on these trucks, he's working on it..
Rochlow is offline   Reply With Quote
Old 03-25-2010, 09:58 PM   #8
kev2809
low n' slo
kev2809's Avatar
man that thing looks good..I'm digging the wheels. what's your rear set up?
sorry for the off topic questions..but i had to ask!
-_--_--_ _________
Old 03-26-2010, 09:11 PM   #9
70RedBlurr
No worries I guess. Here is my rear setup. Still need to brace the notch from side to side and then it will all be covered with the ribbed bed to flow over and cover then notch.
