Old 03-26-2010, 01:42 PM   #26
JRBECK64
Re: Dropped the 64 2 inches in the back
Originally Posted by bobcostas View Post
Can you post a shot of the blocks on the truck??
awesome job, man.
Hope these help.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 03-26-2010, 01:52 PM   #27
bobcostas
bobcostas's Avatar
Thanks! very cool
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 03-26-2010, 06:17 PM   #28
Vernski
Jrbeck64 did you make the blocks yourself or did you buy a kit somewhere?
Thanks....Vernski
Vernski is offline   Reply With Quote
Old 03-26-2010, 07:08 PM   #29
blackmopar
Originally Posted by JRBECK64 View Post
I think I am going to call it good and not mess with it anymore. What do you think?
i think it looks sharp - but i dont believe your statement above after following your threads - its an illness, admitting it is the first step
blackmopar is offline   Reply With Quote
Old 03-26-2010, 07:30 PM   #30
quickchevy
quickchevy's Avatar
What size rim and backspacing and are your wheel tubs stock?
quickchevy is offline   Reply With Quote
Old 03-26-2010, 07:43 PM   #31
JRBECK64
Thanks....Vernski
Vernski,
No I didn't make them but now that I have a set I think I would make the next set. All you really have to do is mark the wholes where they go through the perch on the Diff and drill the wholes then purchase some longer U Bolts. From there you could probably put what ever size block you want in there.
JRBECK64
Old 03-26-2010, 07:46 PM   #32
JRBECK64
Not sure on the backspacing but will measure. The Wheel Tubs are stock. I bought the rims not even thinking about the backspacing. I know the guy asked me if I had Disc Brakes on the front and from there he got me my rims. When your talking about backspacing is that where the center of the rim sets with reference to the back or the front of the rim? Let me know and I will measure it for you.
JRBECK64
Old 03-26-2010, 07:48 PM   #33
JRBECK64
blackmopar,
My Wife would agree with your statement. Everytime I tell her I am going to do just one more thing she gives me the wrinkled brow and evil eye stare. I just have 2 more (JUST ONE MORE THINGS TO DO BEFORE IM COMPLETELY DONE). RIGHT!!!
JRBECK64
Old 03-27-2010, 04:32 AM   #34
quickchevy
quickchevy's Avatar
https://www.rsracing.com/tech-wheel.html
Old 03-27-2010, 08:37 AM   #35
JRBECK64
Thanks for the info.
JRBECK64
Old 03-27-2010, 02:36 PM   #36
sailed2japan
Jonny
sailed2japan's Avatar
JR, The trucks looking good! About the stiffness in the back, it's got to be coming from the axle hitting the exhaust or the bump stops, since you didn't change the springs. I would keep your 3.08 axle in and chnge the exhaust to come out in front of the wheels. I think that is a good look on our trucks. Either that or Y the pipes back together, like factory, but with bigger tubing. Run a single back and over the side w/o the track bar and split it at the back.
A look that I have seen and like is to Y the exhaust under the side of the bed, then run two twin tip exhaust tips so it give a drag car kinda look.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 03-27-2010, 09:22 PM   #37
JRBECK64
[QUOTE=sailed2japan;3885210]JR, The trucks looking good! About the stiffness in the back, it's got to be coming from the axle hitting the exhaust or the bump stops, since you didn't change the springs. I would keep your 3.08 axle in and chnge the exhaust to come out in front of the wheels. I think that is a good look on our trucks. Either that or Y the pipes back together, like factory, but with bigger tubing. Run a single back and over the side w/o the track bar and split it at the back.
A look that I have seen and like is to Y the exhaust under the side of the bed, then run two twin tip exhaust tips so it give a drag car kinda look.[/QUOT
sailed2japan,
Thanks for the advise.
Ive been talking with the guy thats going to do the exhaust for me. Looking at it I think I am going to go wide at the front and go down the outside of the frame rail tucking the pipes as high as I can. Then placing the Mufflers between the frame rail and the outside bed wall then back over the differential and strait out the back. When I get it done I will post some pictures.
Thanks for the compliment,
JRBECK64
Old 03-27-2010, 09:24 PM   #38
JRBECK64
The backspacing is 6 inches and the wheels are 15 by 6 on 6 and 8 inches wide.
Hope this helps.
JRBECK64
