Mounting accessories with headers - A/C and Alternator
So the alternator bracket on my '68 is bolted to the manifolds, and the A/C bracket is also. What have you guys done to mount these with headers?
The A/C bracket is particularly nasty, because I have to pull it just to get the valve covers off! I also Can't use taller covers with that monster bracket. Thoughts? Pics?
1968 LWB C20 / AC / Wood Bed |
Re: Mounting accessories with headers - A/C and Alternator
The header manufacturers usually have brackets you can buy. Cheesy compared to GM's stuff, though. Another reason to run the 'vette Rams Horns!
I tried googling vette rams horns and the results look pretty much like what I have right now. I'm really looking for an aftermarket braket set, or perhaps idea of how to fab up some braces that rely only on the block and heads. I have a few spare bolt holes in my block.
Like I said, most header manufacturers make the brackets. Here is the link to Jeg's and a bunch of brackets as you request. I used to run this style ac bracket on my Jimmy, but ditched it when I went to the 2 1/2" Rams Horns which made as much power as the headers but no bolt/bracket/gasket BS. If you have accessory bolt holes in your heads, I would buy the 69-72 truck alternator brackets.
http://www.jegs.com/p/Dynomax/Dynoma...44716/10002/-1
Redefining LowBudget
I have fabbed some extentions ( spacers out of pipe) and reused the stock manafold bolt or use a piece of threaded rod screw it into the block place a nut to hold your header on it then put another nut on it a washer and then mount your A/C then another washer and nut then you can adjust it back into the location so everything lines up
this works very well Jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
