Old 03-28-2010, 09:51 AM   #1
rebel714x4
rebel714x4's Avatar
rear main ?
my rear main is leaking bad and i need to fix my truck is a four speed ive never done one, can any one tell me how big a pain this is going to be and what all i need to do. Thanks Josh
rebel714x4 is offline   Reply With Quote
Old 03-28-2010, 10:09 AM   #2
low79fx
Re: rear main ?
First you will have to drop the oil pan,then the oil pump if its mounted to the rear main cap.Then you can remove the rear main cap where half of the seal is seated and the other half is on the block under the rear main crank journal,thats assuming its a two piece rear main.you will then need to push that part of the remaining seal out from under the crank be careful not to slip and scratch the crank.If your have an engine maintenance manual or rebuilding manual it will guide you through it.This is diffenantly not for the faint at heart,though not extremely difficult to do,I would study up on the process before attempting as you do expose critical parts of your power plant while doing so.Which could lead to much bigger problems later on down the line.I'm all for learning more and saving a few bucks,but please do be aware.
low79fx is offline   Reply With Quote
Old 03-28-2010, 01:22 PM   #3
62gmc910
62gmc910's Avatar
Re: rear main ?
If you choose to do this seal change yourself look carefully at the lower half of the rear main bearing to check for excess wear, if you see copper replace it with a quality TRW, Federal mogul Clevite , check the back to see if it is marked for oversize. Don't leave the rear main bearing out for long. Make sure you know how to use a torque wrench propperly before you attempt this repair and as stated above good manuals are well worth the money
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 03-28-2010, 04:51 PM   #4
LEEVON
LEEVON's Avatar
Re: rear main ?
Just did one Friday. Here's how it went in my truck, it is an automatic 2wd though:
1) Drain oil, remove pan bolts
2) Remove fan
3) Unbolt engine mounts
4) Hoist engine up 3" or so
5) Slide oil pan out
6) Remove oil pump
7) Remove lower rear main bearing cap
8) Remove seal
9) Clean, clean clean
10) Replace seal (offset a bit)
11) Replace cap w/ seal (offset a bit, small amt of sealant, torque to 70 ft lbs)
12) Replace oil pump, torque to 115 in lbs
13) Replace gasket and pan
14) Replace mount bolts and fan
Clean up giant mess!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
