Old 03-27-2010, 10:48 PM   #1
sswitzke
sswitzke's Avatar
Brake help please
I'll say it first, I'm an idiot. When bleeding brakes, you hold the pedal down then open the bleeder, then close it and then release the pedal?
1967 Chevy long bed
1966 Chevy short stepside
sswitzke is offline   Reply With Quote
Old 03-27-2010, 10:54 PM   #2
spatz
Re: Brake help please
that is the correct way, with the master filled and the cap on to prevent spills.. also if by yourself, you can fill the master, leave the cap off and open the farthest bleeder from the cylinder and let it gravity bleed untill a good flow w/o bubbles comes out, close the bleeder and go to the next, while monitering the fluid level in the master. when done with the bleeding, fill master, cap it off and pump the brakes a couple of times. Then repeat gravity bleeding until no more bubbles appear.
spatz is offline   Reply With Quote
Old 03-27-2010, 11:04 PM   #3
Mike J
vw guy & now c-10 guy
Mike J's Avatar
yeah, pump up the pedal 4-5 times and hold down- have someone open bleeder, let bubbles out, close bleeder, repeat process til you get nothing but solid fluid, no air- and start farthest from the master cylinder- RR, LR, RF, LF
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 03-28-2010, 05:06 AM   #4
cdowns
cdowns's Avatar
theres a pin on the prop valve that needs to b clamped to properly bleed brakes//people without service manuals dont know about that step
Old 03-28-2010, 06:15 AM   #5
Sinister
Between Trucks...
Sinister's Avatar
I use a one man brake bleeder kit you can get at an auto parts place or Harbor Freight for like $5. It's a little bottle with tubing and a magnet on it. You open the bleeder , hook it up, stick the bottle to the truck above the bleeder, pump until there's fluid in the bottle, close the bleeder and your done.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-28-2010, 10:56 PM   #6
sswitzke
sswitzke's Avatar
ok bleed the brakes no air in the line. Pedal still goes to the floor very little to no pressure on the rear wheel cylinders. Any ideas?
1967 Chevy long bed
Old 03-28-2010, 11:32 PM   #7
Dark Knight
Dark Knight's Avatar
If your pedal sinks to the floor, then it's most likely a bad master cylinder.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 03-28-2010, 11:37 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Let's go back to the beginning.
What started all of this brake bleeding?
Did you change something?
Did the brakes just go out?
Replace a wheel cylinder?
We need the whole story.
Keith
Convert to disc brakes.
Old 03-29-2010, 12:14 AM   #9
sswitzke
sswitzke's Avatar
When I bought the truck you touch the brakes it would put you into the front glass, check the brakes and they were all cracked down the middle. Front drums looked good back two were junk. changed brakes all around two new rear drums. Took one side apart replace brakes move to the otherside. Put the wheels back on try to move truck and the pedal goes to floor barley stopping truck, did the reverse brake a couple of times well dozens of times. Checked fluid rear wheel was empty added fluid and still nothing so I tried bleeding the brake lines.
1967 Chevy long bed
Old 03-29-2010, 06:02 AM   #10
lolife99
lolife99's Avatar
Was the master cylinder full prior to changing the brake shoes?
The fluid doesn't get out of the M/C by itself.
You have a broken steel line, bad wheel cylinder or bad M/C.
When you did the rear brake shoe replacement,... was it really wet under the brake drum?
Keith
