Bought a truck, need advice
I bought a 1968 C-10 longbed back in Sept 09. I've been piddling with it for awhile, but due to work, family, and life in general I haven't made much progress.
BOHICA
Re: Bought a truck, need advice
everybody likes to do things in their own way. I would recommend doing all of the mechanical stuff first. It would hate to drop a wrench on a freshly painted fender, or have welding and grinding sparks flying onto new paint or glass. By the way if you want disks up front, you can swap the whole front suspension off of a later model truck. I believe any from '70-'80 will work, but not sure. Someone will correct me. Lots of these truck laying in scrap yards so finding one should be easy and cheap. Theres only 14 (I think) bolts holding it on. Check out the vendors and search the board for parts and answers.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
Factory Strippers Rule!
![]() Join Date: Mar 2009
I would get it driving safe first. If it still cruises around town, you won't get discouraged as easily because you will still get the enjoyment of driving it. Once it comes apart, it tends to stay apart for a LOOOOOONNNNGGG time...
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
3rd vote for mechanicals first, to at least get it safely drivable. Then just do the body and cosmetic work as time/budget allows.
That's pretty much what I did on my 68 CST, and I've been having a good time hauling stuff around in it while I ponder future improvements and projects. And drum brakes aren't as bad (or unsafe) as most people make them sound, you just can't stop on a dime like you can with discs, but they slow the truck down just fine, even when loaded down. Keep in mind that swapping to disc brakes also usually requires a change in wheels, because of backspacing issues or the calipers get in the way. Sometimes you'll get lucky and only a bit of grinding is needed on the caliper to get it to fit, but more often than not, it takes a bit more than that.
David 1968 Chevy C-20 CST LWB Fleetside |
Definately focus on the mechanical and any saftey issues of the truck first, if your planning on or currently driving it daily. Cosmetics always come last for me.. And doing that much work to a cab (rockers/corners/floor/supports etc) will take it off the road for quite some time.. I am no expert welder / bodyman but it took me a good solid 2months to get my cab cleaned up doing pretty much the same you have too..
![]() Join Date: Dec 2008
I agree with the above advice take care of mechanicals. Drive and enjoy while fixing. Terry
1972 Custom/10 Deluxe SWB 4wd " The Green Gobbler" |
![]() Join Date: Dec 2009
Safety first. Then the rest. I changed the front from and 84 in to our 67. Its easy. dozen or so bolts a little drilling and bolted right up. Plus Tires and Wheels count as Safety items. Good Luck
Very good advice. Thank you all. I'd much rather have discs, but drums will have to do for now I suppose. Switching to discs sounds like it can get expensive! I'd probably have it on the road by now, but I figured I would take the time to clean up and/or replace the front suspension and steering components while I was under there. I guess I'll do the whole "tune up" thing from there and see what happens. No doubt I'll be in touch so I can benefit from everyone's expertise on here. Any further tips/advice you care to share would be great! Thanks again.
I was able to get an entire rolling chassis from and 84 for 200. Everything was in good shape.
Again i was in a similar situation.. my 68' had front drums and I was wanting to go with discs but retaining my 6lug pattern. In the end even though I had the whole front clip off (for the first time) and it would have been a great time to do everything, I had to opt out due to cash flow. What I did end up doing was slowly buying everything needed for the swap, as well as other front end parts (bushings, ball joints etc etc) as I could afford them throughout last spring/summer... and when I had everything accumulated.. I pulled her into the shop this winter and went to town.
Most costly parts for me on the front end were the 6lug disc swap kit.. I actually bought two sets of rotors since they aren't a over the counter part.. and ccp, I think it was, had them on sale at the time. Also the mc/booster setup can be costly depending on where your at and whats available.. i live in the middle of no where so parts aren't cheap to ship to me ![]() |
68 C10 SWB
here's some advice, POST A PICTURE~!
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman |
#12 | ||
"I ain't nobody, dork."
My truck has rotted out rocker panels, holes on the floorboards, dents in the passenger side of the bed that the PO had tried to bondo, a bent front bumper, the hood don't line up worth a darn, a rusty old step bumper, the drivers side window always falls down when I'm driving...
But... pop the hood and it's all go fast under there... rebuilt tranny to boot... new brakes, and new u-joints, gonna tear in to the rearend next. Also gonna lower it 4" in back and 2" up front. Basically... a rusty farm truck that hauls a$$... So get the mechanical stuff out of the way first. More funnerer to be able to drive it around, and work on the cosmetic stuff later. Heck... I'll prolly never do any of the cosmetic stuff. I like when the 400hp small block roars to life and leaves a pile of rust on the garage floor under the rocker panels... ![]() Gary
I'll have to get a picture posted. Not much to look at though! I've seen people talking about 20" Dodge steelies. That would would be alright. I'll probably start piecing the front disc brake system together. What about a wiring harness for the engine? Should I go with one from a junkyard or what?
#14 | ||
Junkyard wire harnesses are just that... mostly junk. Especially from a truck that old. There are great aftermarket wire harnesses available for decent prices. I bough a front light harness and engine harness (w/HEI hookup) from Wes at Classic Heartbeat for my 1972 GMC 1500 Super Custom. I know he's a member here...
EZPZ plug and play... correct plugs for the firewall, and all the correct factory hookups, and mounting fixtures. Plus they came with new plastic wire runner channels to boot. They look way better, and are a lot less headache that some old, brittle, greasy, harness from a junker. I might add that Wes is local for me... so I bought a lot of stuff from him and Franks' Pick'em Ups. Another local guy for me. That is a member here too. I try to support my local guys. ![]() Gary
#15 |
Does Wes have a website? How much did the light and engine harness set you back? So does switching to HEI just consist of installing an HEI distributor? I have a Mallory ignition system that my friend gave me a few years ago. He had originally bought it for a Mustang. Think it will it work on my truck? I suppose I would need HEI to hook that up, right?
