Look at These
here are a couple pics of my passenger outside floor and where the floor meets the rocker. what patch panels would work on this without buying too much floor.
Re: Look at These
Are you doing inner and outer rockers too or just the floor? There's a piece out there that will do that piece of the floor and the inner and they aren't priced too bad.
Re: Look at These
no rockers or inner rockers......just the outside of the floor next to the rocker from where seat mounts up next to the kicker panel.
Under Construction
Re: Look at These
it''s called the outer floor extension... but as Marq asked do you plan on removing the out rocker? or just repairing the floor? if you plan on removing the outer rocker and cutting that section out to repair the rust the outer floor extension will work for you. if you just want to repair the floor without removing rocker etc. buy some sheetmetal and cut and fit patch panels, then weld em in.
I guess i typed too slow as you answered the question before i submitted this post.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 03-30-2010 at 11:27 PM. |
#5 | |
Re: Look at These
Under Construction
Re: Look at These
with that being said you would have to either cut up an outer floor extension ( has a 4" lip and should repair that), or a front floor patch piece. If you dont plan on removing the out rocker for repair...... I would just get some sheetmetal from a local supply house and make patches. check with board vendors for pricing of sheetmetal parts. wes @ classichearbeat.com or MBGMike @ http://bumpandgrindgarage.com/ are a couple of vendors that come to mind....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 03-31-2010 at 08:13 AM. |
