Old 04-02-2010, 10:41 AM   #1
CARR33
What year frame
My 67 has power steering. It was on there when i got it. After reading about power steering swaps i see where the 67 frame will hit the steering box without a spacer. My frame has the proper indentation for a power steering box. It doesnt appear to be heated and hammered in, it looks factory. Is there any way i can determine what year frame it is. I'm getting ready to do a front end rebuild and want to order the right parts. It has front disc brakes and the spindles look factory.
CARR33 is offline   Reply With Quote
Old 04-02-2010, 11:18 AM   #2
Duncan and son
Re: What year frame
Carr to do a front end rebuild any of our years 67-72 would be the same. The fact that yours has the PS indention is good and indicates 68-72. Disc brakes are only on 71-72. You can check the actual yr by looking on driver side toward the front on top of the frame for some stamped no's. The first no. indicates yr. The holes where the core support mounts are about the size of a quarter to half dollar on 67 while the other yrs the hole is about the size of a silver dollar.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 04-02-2010, 11:24 AM   #3
sweetnlow67
sweetnlow67's Avatar
Re: What year frame
i have a vin decoder, if the vin is stamped on the frame i can tell you what year it is if you tell me the vin
sweetnlow67 is offline   Reply With Quote
Old 04-02-2010, 03:39 PM   #4
CARR33
Re: What year frame
Thanks for the info!!!!!!!!!!!knowing where to find something this important is great info. The number on my frame is 7s195453. The vehicle vin is cs147s195453. Thanks again
Old 04-02-2010, 09:42 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: What year frame
I've actually personally seen a factory 67 frame that was dimpled for power steering originally. It must have been a running production change late in the model year run.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
