Happy to be here
![]() Join Date: Mar 2000
D52 caliper upgrades
In response to the recent post by Chuck "My whole braking system - thinking out loud" and the ensuing conversation regarding updating the rear brakes to disc with calipers that match the fronts, I did some research.
The stock front caliper (D52) is very common on many GM trucks and cars. There are several direct replacement units available, but they aren't really considered an "upgrade". My focus on this search was to find direct bolt on calipers that would offer better braking than the stock single piston D52. The applications below meet that criteria with the exception that some do require replacing the flex house as well. I also included several replacement rotor choices. Keep in mind this does not cover any "Big Brake" upgrades. I feel that is an entire different category in it self that I hope to cover in another post. If you have any other options please post them along with a source link. D52 options- Summit- Wilwood GM D52 Calipers Brake Caliper Aluminum, 164.99 Each ![]() Power Stop AR-8600SL 69.95 Each ![]() Power Stop AR-8600L 79.95 Each ![]() POL- #18346- DUAL PISTON CALIPERS GM TYPE 389.00(PAIR) Requires braided stainless brake hose kit #-DPSBH. Add $79.10 #19569 LARGE GM D52 ALUMINUM CALIPERS DUAL PISTON 349.99 (PAIR) Upgrade to polished, add $75. #18292 CROSS DRILLED AND GAS SLOTTED ROTORS 79.00 (PAIR) #18290 CROSS DRILLED ROTORS 49.00 (PAIR) #18288 GAS SLOTTED ROTORS 49.00 (PAIR)
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: D52 caliper upgrades
Ken,...
I assume those pictures of "hat style" rotors are just "sample photos" of the slots or drilled holes, since they obviously won't work on the front of the 67-87 trucks?
It'd be alot cooler if you did
Wow the POL rotors are cheap!
*EDIT* Price does not include rotors only the machine work... Last edited by smashingchuck; 03-26-2010 at 01:27 AM. |
60-66 Nut
While they don't have the 'Bling' of the Wilwood dual piston D52's the factory option JB7/JD7 calipers have 3 5/32" dia pistons. I'm about 90% certain these are based on the D52 caliper castings. My computer is running extremely slow, or I would find some verification tonight. I'll look some more tomorrow. IIRC the standard JB5 and JB6 calipers have 2 15/16" pistons.
carcraft put the wilwood calipers on a few cars and said they worked amazingly better
Never Done?
![]() Join Date: May 2000
http://cgi.ebay.com/ebaymotors/71-87...item2303780ba6
POL has the "ugly" wilwood dual piston on eBay for $249/pair right now. |
#7 | |
Happy to be here
I know most of the referenced thread is referring to calipers for a rear conversion, but your going to need rotors to match so I pulled that up as well. This is here so we can discuss options with out mucking up Chuck thread.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-26-2010 at 08:43 PM. |
so these take you from a single piston to a dual piston. These will fit where ever the stock calipers fit assume?
looks like a decent upgrade. My brakes work good right now but I would guess be much better after this... Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#9 | |
With out a doubt.... they look better ![]()
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-27-2010 at 12:08 PM. |
#10 | |
motor exploder
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#11 | |
Active Member
Total piston area per caliper:
OE C10 = 6.777 D52 = 6.584 CPP Big Bore S-10 = 5.940 OE S-10 = 4.909 Corvette 40mm = 3.896 Corvette 38mm = 3.516 The D52 is the most close to the OE piston area. We use 52mm pistons in our big brake kit with the 13" rotors. One advantage with our claiper is the pad area is much larger. This gives better performance, lower pad temps, and longer pad life. You also might have noticed how small the Corvette cliper is. Danny Nix CPP |
#13 | |
do you know what are the thickness of those rotors.
i´m planning on using mcghaughys drop spindles on my ´67 c-10 but i read that they must use heavy duty rotors. do you know if the rotors in this post fit these spindles? or know another rotor caliper combo that fits the spindles. tnks Quote:
60-66 Nut
You will need to use the 1.250" thick rotors with the McGaughy's spindles. You can get the Wilwood D52 calipers to fit the 1.250" rotors, or you can use OEM style D52 calipers for the 1.250" rotors.
#15 |
I used the POL D52 calipers along with summits drilled/slotted rotors.
IMO you can change rotors and calipers, but don't over look the brake pads too. You can gain a lot of performance by upgrading the brake pad even on the stock rotors/calipers. |
#16 |
motor exploder
Yesterday I ordered the POL calipers that Ackattack has (thanks to Alvin's heads up in the post above), along with some zinc plated drilled/slotted rotors. I am using Impala rotors on the rear with Glock's brackets running the Camaro calipers. The front is CPP drop spindles (the regular 73-87 version) and CPP tubular upper/lower arms.
#17 |
are the wilwood calipers available in 1.25" rotor thickness or should use thiner pads??
#18 | |
didi you use heavy duty rotors?? |
#19 |
motor exploder
Yes, the Wilwood D52's are available in two versions, one for 1.25" (heavy duty) rotors, one for 1" rotors.
#20 | |
Initially I used ECE 2-1/2" drop spindles, but swapped them out for the CPP modular drop spindles since I didn't have enough back spacing on the front wheels. I used these rotors, they're 1-1/4" thick http://www.summitracing.com/parts/SUM-DSEP-5516L/
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 04-02-2010 at 07:36 PM. |
#21 | |
by the way great truck that bruiser! |
