Old 04-03-2010, 06:10 PM   #1
lblampman
Little off-the-wall project for '78 C30
Greetings all,
I've been reading the forums here for a while and trying to learn what I can to pursue an idea I have for a project. I'm hoping to gain some more insight from all you fine folk (maybe just before I step off the cliff, rather than just after )
I have a 1978 C30 based Beaver class C motorhome. The camper part is about done for after 32 years but the truck is acutally in pretty nice condition and I want to use it as the base for an expedition style camper.
I want to keep this truck if I can for the project because it's only got 33,000 original miles on it and because the extended frame is perfect for the size camper box I want to build. It has a 454 with an automatic, and has duals. The cab is really straight and quite frankly, I'd like to keep it on the road rather than it ending up in a junk yard somewhere.
So here's where I need the collective wisdom gathered here as I don't have a lot of background in these trucks like a lot of folks here.
The idea is to strip the Beaver motorhome body off competely and to build a 14' expedition style camper (basically a box, it won't have a cabover portion and will be much lower than the Beaver motorhome camper part is now).
The part I'm not so sure of is how best to get maximum ground clearance since this isn't a K30. I'd like to install an air locker and a winch on the front. This won't be a real "off road" vehicle and I don't intend for it to be but I do want to use it off pavement and well off the beaten path (Alaska, Baja, southern Utah, beaches, etc); eventually south through Mexico into Central America, and perhaps shipped to South America.
I think I'd also like to have single tires in the back rather than the duals; is this something that's relatively easy to change?
And if I did want it to be 4x4, what does it take to make that change (mostly parts acquisition and installation, or a lot of fab work)?
This is the best time for me to get input, so please don't be shy with your thoughts, ideas, and comments (hopefully constructively ).
Thanks!
Les
Whidbey Island, WA
lblampman is offline   Reply With Quote
Old 04-03-2010, 07:55 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Little off-the-wall project for '78 C30
Welcome to the forum lblampman. The first thing you should know is we are all pic freaks. If you have a chance post some for the gang.
I don't think your project is too crazy. The first thought is how to build your box and make it durable with out being too heavy. If you can get past that concern you should be fine.
As far as the rest of your ideas, I suggest you shop for a K/20 or K/30 truck that you can use for parts. If you can find one in worthy condition you might even consider swapping your cab/clip to the 4wd frame.
If not, your C series can be converted to a K series. You will need a long list of 4wd parts to get the job done.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-03-2010, 08:07 PM   #3
lblampman
Thanks much for the welcome! Signed up a few months ago but have just been reading and learning during since then.
The box (at least for me) is the easy part, it's the truck that gives me the most challenge (just due to my background and skill set). I thought about just getting a K30 but I would have to cut and extend the frame and redo the driveline. Honestly...I'm just not sure which is the easier path to follow (redo my current truck or start with a 4x4).
Good ideas and I appreciate the thoughts, good to get different viewpoints.
Les
