Floor pan temperature?
I'm in the middle of installing new carpet in my truck. I've got the old vinyl flooring and padding out, but am waiting for the carpet to arrive.
I've noticed that the floor pan gets hot under the seat - it even melted a spray can lid into a puddle. ![]() Just wondering if anyone else has noticed this before and if it's something to be worried about. As far as I can tell the exhaust is the normal distance away from the floor. I can try to take a picture of the exhaust tonight if it would help. Any wisdom? |
It'd be alot cooler if you did
Re: Floor pan temperature?
Plugged converter? Shouldn't run that hot.
I was wondering about the cat converters. The truck's an '82 and it's got two converters that look original.
Unfortunately, at some point the exhaust was replaced and they welded the converters in, so I can't just unbolt them and take a look. No flanges left. ![]() |
Well that would be the first thing I eliminated. Fire up that saws-all.
![]() Join Date: Apr 2005
No way should it get that hot! When the PO mucked with the cats, did they take off the heat shield? There should be a heat shield on the top of the cat to protect the cab floor.
Good idea - I'll check for that. Maybe they welded the cats back in upside down!
When I got my Burb, it was down on power and the floor would get hot while on the freeway. I thought it was a plugged converter, so it was replaced with headers and duals. It helped, but not much. It ended up being the timing, it was set back WAY too far. Now there is power and the floor has stayed cool ever since.
#9 | |
Engine is way down on power though, so maybe that's playing into it. |
you can get a new or used non computer controlled hei distributor for close to mothing.. id do that.. and take the cats off.. itll sound and flow better
"I'll keep my guns, money, and freedom. You can keep the "change" |
After driving home from work tonight I checked some temperatures around the truck. The drive was about 30 minutes of suburban driving - all 35 and 45 mph.
I used a non-contact IR thermometer and found these temps: Floor at pedals: 101 F Under driver seat: 120 F Under passenger seat: 175 F Driver side cat converter: 350 F Passenger side cat converter: Off the scale All winter I just thought I had a great heater! ![]() |
#12 | |
![]() I'm going to look into the cats this weekend. If they're as old as they look, and I don't doubt that they are, there's no way they're happy. This truck's my daily driver, and I sure don't want that heat hitting me all summer. |
both are reletively cheap and easy projects. (less things to go wrong, more power)
#14 | |
#15 |
Here's an article which talks about switching from ESC to non-ESC distributor. It even tells you how to disable the ESC on your existing distributor!
http://www.73-87.com/7387garage/drivetrain/escrepl.htm |
#16 |
USSkoval: No I didn't. Is that how you can disable the ESC to set the timing? I'll have to do that and see what happens. Thanks!
Turbo85GMC: Thanks for the link; I'll look into that. |
#17 |
Yeah, if you don't disconnect that wire, the timing will be set back too far. I think that's what someone had done with mine, causing the lack of power. IIRC, the connector is along the firewall on the driver side.
#18 | |
I don't see a tan wire in my ignition system. The distributor has pink, black, white, green and brown. I see from the link that Turbo85GMC posted that you can interrupt the ESC by shorting Green and Black. I'm not sure I want to do this, though, since the distributor doesn't have any mechanical or vacuum advance on it. Eventually, I'd like to replace the distributor with a non-ESC one. |
#19 |
haha, ford guys...
there should be a heat riser in between the exhaust and the bottom of the floor board. alot of ol'timers took em off because they collect mud on the farms.
#20 | |
#21 |
Three-way-converters also tend to get extremaly hot, to the point that a heat sheild is usless, if your truck is running rich. We had a huge arguement in class today about them on just ripping em off and tossing them. Wyoming has no emisions laws so most older trucks tend to not be set up for it here, i know mine wasnt when i bought it.
#22 |
Thanks to everyone for the input on this thread. I got the catalytic converters "fixed" yesterday and finished up my carpet install today.
![]() Check out the carpet install in this thread. It turned out really nice and classy. . |
#23 |
haha, ford guys...
haha sorry ive been super busy.. some one most likely took it off. they always rattle... the 86's were fixed.. and in 92 they changed the style, and it rattles once again... fixed in 1999 or 2000-current
Pfff. engineers. |
