Old 04-03-2010, 11:22 PM   #1
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: Project 50th C5 Blazer
I do, it was the one we painted some silver over.
If you look over these pic, you can see one of the original holes lined up perfect
I believe it was the middle hole of the three on the frame. I can go a take a cloer look if you need me to.
Hope this helps a bit
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-15-2010, 04:42 PM   #2
wholio
wholio's Avatar
Drew
thanks bro, ok well here's the thing i took the suspension off of a 1967 c10 like the front cross member and the rear coil suspension , and im in the middle of installing it on my 1969 k5 blazer 4x4 frame to convert it to 2wd, well i keep measuring and it keeps making me land on the first hole not the middle hole, im thinking i measured wrong maybe from the front cross member
but idk im someone stuck on this step, the other thing is home of my homeboys already drilled the front crossmember holes =/ he said hes is 100% sure he measured right but i dont think he did, but yeaha if i was to move the trailin arm crossmemeber to the middlehole i wouldnt come close to a 104 wheel base (i measure front the middle of the rear axle to the from crossmember like the back)
wholio is offline   Reply With Quote
Old 04-15-2010, 04:58 PM   #3
wholio
wholio's Avatar
heres some pictures to better describe what im talking bout, the pictures show the from cross member mounted to a persistent hole on my 1969 frame and they also show the trailing arm cross member mounted to the first hole as i stated before, and it shows where the rear axle would be if bolted down to the first hole on the stock bump stop on the 4x4 frame...http://67-72chevytrucks.com/vboard/i...vil.gif:smoke:
Old 04-15-2010, 05:13 PM   #4
wholio
wholio's Avatar
i attached the wrong picture for the front hole
heres the right ones
Old 04-19-2010, 12:43 PM   #5
Twisted78SS
Wide n'Low
Well, here is what I will do,
I'll make some measurements on my frame and post them here. It will be a day or two since I have some work things going on the first half of the week. Hopefully it will clear up your questions and concerns, and mine too!
Air Force Retired
Old 04-20-2010, 02:09 PM   #6
wholio
wholio's Avatar
thanks bro
nice looking out
