Old 04-04-2010, 10:08 PM   #1
56fleetside
///RELAXED ATMOSPHERE
56fleetside's Avatar
Wanted
In for a simple satchell link and bags on 20's with ball valves(owner is gonna plumb/wire and also a suicide drivers door.....Its a stepside truck and hes getting a deep and wide 20 so we will also be narrowing the rearend and also rebuilding it with a locker and new gears
Like a BOSS
56fleetside is offline   Reply With Quote
Old 04-04-2010, 10:09 PM   #2
56fleetside
Re: Wanted
Took the shock indentions out of the frame to make it stronger since he'll be drag racing this thing on occassin ill also be doin some extra gusseting on the rails once a few xmembers are removed
Frame Z'd still gotta level engine and build trans xmember
Like a BOSS
Old 04-04-2010, 10:10 PM   #3
56fleetside
Re: Wanted
Fabbed a trans xmember
ready for narrowing rearend and fabbing rear link setup
Like a BOSS
Old 04-04-2010, 10:10 PM   #4
56fleetside
Re: Wanted
John and John do a suicide door hahahaha
to get the hinges far enough apart to be stable we cut lower cab corner out and will be boxing it in around the hinge once complete
pockets started and door swangin....notice the slot between hinges we cut it then inserted a 1/4" plate to tie upper and lower hinge together and also tie into skin
back door jamb cut out and formed with 1/4" plate then all of it rough bodyworked
suicide do suicide doe
not even close to touching cab
start of the latch.........using stock one since only one door is getting suicided
Like a BOSS
Old 04-04-2010, 10:12 PM   #5
56fleetside
Re: Wanted
boxed the rails with 1/4" plate
cut axle housing down 2 1/2 inches per side and got axles from Moser
Like a BOSS
Old 04-04-2010, 10:12 PM   #6
56fleetside
Re: Wanted
Like a BOSS
Old 04-04-2010, 10:13 PM   #7
56fleetside
Re: Wanted
Finished up this trips fab work 2 weeks ago, Robby took it home to mount bed, wire/plumb, get running then its coming back for a custom dash/console/door panels, sheetmetal work on the rear fenders and front step area to make it look right and a sheetmetal bed interior
Robby sent a pic from home with the bed back on......gonna take some work but i got some ideas to make the stepside bed flow alot better
Like a BOSS
Old 04-04-2010, 10:21 PM   #8
joe231
joe231's Avatar
Re: Wanted
nice work!
gotta love the dimple dies!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-04-2010, 10:30 PM   #9
SatisTraction
Re: Wanted
another ms boy!!
nice custom work for sure.
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 04-04-2010, 10:35 PM   #10
bigdnew
Never Satisfied
bigdnew's Avatar
Re: Wanted
i sure could use that trans member you built.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 04-04-2010, 11:32 PM   #11
tswore
built not bought
tswore's Avatar
Re: Wanted
Originally Posted by joe231 View Post
nice work!
great lookin fab work! makes me want to go weld somethin!
MY BUILD THREAD "project: what you doin that for?"
http://67-72chevytrucks.com/vboard/s...d.php?t=382503
tswore is offline   Reply With Quote
