B&M Shift Kit for TH350C?
The B&M Shift kits only say TH350 and not TH350C, but the Transpak says TH350C, but it's twice the money, anyone know whether or not the regular shift kit will work in the TH350C?
Link to Shift Kit http://www.jegs.com/i/B%26amp%3BM/130/30262/10002/-1 Link to Transpak http://www.jegs.com/i/B%26amp%3BM/130/30235/10002/-1 edit: I'm 99% sure I have the TH350C, since it seems like I have a lockup converter, but if someone knows how to tell for sure, I'd appreciate the know how. Last edited by qu1cks1lver56; 04-05-2010 at 09:13 PM. |
Re: B&M Shift Kit for TH350C?
If you have a lock-up th350c there will be a 4 prong/wire connector on drivers' side of the tranny.
Are you planning on installing it yourself? If not then the trans shop can give you a shift kit (modify trans) without having to buy the kit. Last edited by HOGDADDY; 04-05-2010 at 10:07 PM. |
Planning on me and a mechanic friend of mine installing it, I'm not too sure of the 4 prong connector, but there is a vacuum switch on the firewall.
