04-05-2010, 09:54 PM | #1 |
longer U-bolts?
well i put 3" drop springs on the rear of my 71, but its not low enough. so i decided i will make 2 inch blocks and a longer track bar from some bushings ive got layin around. but were can i get longer u-bolts? i know POL and ECE offers everything i need,but i want to build it my self (for fun, bordum). i was wonderin if i could pull u bolts off of a different vehicle that will work or were can i buy just the u- bolts? thanks
04-05-2010, 10:05 PM | #2 |
Re: longer U-bolts?
I went to a local spring shop and had a set custom bent... Cost about $10 per bolt with nuts... Just take your old one with you...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-05-2010, 11:16 PM | #3 |
Re: longer U-bolts?
if you take the measurements that you need most any autoparts store with a counter person that know how to read the books can get them 4 u
04-05-2010, 11:30 PM | #4 |
motor exploder
Re: longer U-bolts?
x2 - this is the easy way to go.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
