Old 04-07-2010, 04:23 PM   #1
71stub
71stub's Avatar
Under Bed Gas Tank Suggestions
I'm working on a budget truck and would like to find a stock gas tank from a salvage yard that fits between the frame rails well on a 1957 shortbed behind the axle. I tried one from a Bronco 2 and it fits between the rails nicely but hangs way too low and only has a couple of inches clearance on my lowered truck. It is the 23 gallon tank and is the only tank that I have found online for them but read somewhere that they work well on these trucks. Maybe if you have a 4WD and dont mind the tank hanging well below the roll pan/bumper. Any help is greatly appreciated. Thanks.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 04-07-2010, 04:27 PM   #2
bobinbc
bobinbc's Avatar
Re: Under Bed Gas Tank Suggestions
I think the older blazer and suburban tanks work....
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 04-07-2010, 04:38 PM   #3
71stub
71stub's Avatar
The 73-87 styles? I know some of the Suburbans had up to 40 gallon tanks. How big of tank will fit?
Old 04-07-2010, 06:00 PM   #4
blackdiesel
blackdiesel's Avatar
70 mustang
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 04-07-2010, 06:29 PM   #5
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
70 Mustang/Cougar: 18 Gallon tank will do you right.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 04-07-2010, 07:46 PM   #6
floridasteve
floridasteve's Avatar
Some of the best advise I ever got was a mustang tank for the trucks. 1-It has a flat top and the fill is also on the top. 2. The 64-69 Mustang I believe is the smaller size and the 70 is larger meaning it sits just a little lower in the rear. I will post pics in the next post as I have to locate them. 3-PRICE $88 bucks brand new on ebay.
This is the kind of stuff I got on this site for. I don't have the 400-500 to order one from the rod shops. It is a great fitting tank.
One day I am going to finish this project!
1949 Chevy 1/2 ton
floridasteve is offline   Reply With Quote
Old 04-07-2010, 08:02 PM   #7
floridasteve
Here is one of the attachments
1949 Chevy 1/2 ton
Old 04-08-2010, 12:35 AM   #8
drivea55
drivea55's Avatar
and Bingo was his Name-O
http://cgi.ebay.com/1970-70-Ford-Mus...item5d2892905e
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 04-08-2010, 08:53 AM   #9
Houston54
The universal tank from Tanks, Inc is what I am running on a 54. Capacity is 16 gallons and cost is about $215 with free shipping.
Make sure the gas gauge you are using is compatible with the sending unit in the tank before you make a decision. If you are using the stock gauges the ford sending unit will not work.
If you are using aftermarket gauges you can get a gauge to make the ford sending unit ohm range.
If you are planning to run your exhaust out the back you will need to ensure you have about 3 inches of clearance between the tank side and the leaf springs if you have not changed to another suspension system.
Houston54 is offline   Reply With Quote
Old 04-08-2010, 06:11 PM   #10
floridasteve
The info is correct the GM is 0-90 ohm and the Ford is something like 72-7 ohms so the gauge will be off and backwards if that makes sense. That's how it was told to me anyway. I put in the GM sending unit after attaching it in the Ford sending unit location. I had to change the arm a bit but I have no reason to believe the float will work just fine.
1949 Chevy 1/2 ton
Old 04-08-2010, 08:09 PM   #11
mixermike
mixermike's Avatar
i'm so happy i ran across this thread . YOU GUYS ROCK
mixermike is offline   Reply With Quote
Old 04-08-2010, 09:02 PM   #12
entourageguy
Yellow truck club
entourageguy's Avatar
we're here to help. It is a great place of info that's for sure
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 07-13-2010, 11:17 PM   #13
wigadore
wigadore's Avatar
@floridasteve
How did you rig up this tank to fit under the frame? I just bought a tank from a guy parting his 71 Fastback Mustang project and it matches the measurements off the 70 gas tanks I found for sale on ebay. This one cost me $30 and it was just down the road two blocks so no having to wait!
wigadore is offline   Reply With Quote
Old 07-13-2010, 11:57 PM   #14
nikwho
nikwho's Avatar
is there much of a difference between the 18 gallon tanks and the 22 gal tanks?
Other than four gallons! :-) Would a 22gal. tank hang down much more?
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 07-14-2010, 12:29 AM   #15
mr48chev
mr48chev's Avatar
I am planning on using a 79 Blazer tank as noted on another thread but the Mustang tanks do appear to have some advantages. 29x29x11.5 outside dimensions including the hoses and fittings on top for the Blazer tank.. The main body is 9-3/4 deep.
I have a 40 gallon 90 something burb tank for my 71 but it is quite a bit larger and deeper than the Blazer tank.
Old 07-14-2010, 07:57 AM   #16
floridasteve
@wigadore
I used flat stock and angle iron to form a tray in which the tank drops into. The two sides that run perpendicular to the frame rails were drilled and bolted to the frame. The tank also has holes to bolt the tank to the frame I made using the stock holes in the tank. My second post of pictures should give you an idea of the set-up.
1949 Chevy 1/2 ton
Old 07-14-2010, 11:08 AM   #17
blackdiesel
makes perfect sense. half a tank on the gauge is actually a full tank, and a full tank on the gauge means you need to find a gas station...
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 07-14-2010, 11:26 AM   #18
63 & 64 Bowties
and a few others
I can tell you for sure that on the 70 Mustang tank the mounting flange is not level with the top of the tank like the 64-66 is. I know because my brother and I are restoring a 70 Mach 1, and we've done several 64-66's. On the 64-66 the top of the tank is level with the mounting flanges and when installed becomes the trunk floor. Hope that makes sense.
Here's a shot of our 70 tank....
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-14-2010, 05:32 PM   #19
ambryatim
ambryatim's Avatar
I am gonna use a 73-81 blazer tank on mine, insted of restoring the old one. Then I will fab up a filler door in the fender.... I think they are like 80-90 dollars new on rockauto.
ambryatim is offline   Reply With Quote
Old 07-16-2010, 11:50 PM   #20
Dan in Pasadena
Dan in Pasadena's Avatar
I've got a Ford tank of some kind in my '46 Chevy that has the "ring lock" type fuel sending unit mount but the aftermarket gauge and sending unit uses the typical 5 or 6 hole mount. Does ANYONE know of someone who makes an adapter? I've tried Summit, Jegs, No Hollywood Speedometer with no luck.
Dan in Pasadena is offline   Reply With Quote
Old 07-17-2010, 09:36 AM   #21
mr48chev
mr48chev's Avatar
I've never seen an adapter for that Dan. I think what some guys are doing is cutting another hole for the aftermarket sending unit in the tanks. Another option would be to modify the Ford unit and use it as an adapter but then you may loose it as the fuel pickup then.
Old 07-18-2010, 02:11 AM   #22
Dan in Pasadena
Thanks Mr. 48. I've been procrastinating but what I have thought of doing is just removing the Ford sending unit and basically just cutting off or grinding off all the parts other than the perimeter ring which interfaces with the tank. Then probably use JB Weld to mount the sending unit I got with my gauges on it. I wonder how gas resistant JB is?
Old 06-17-2011, 06:21 PM   #23
VALDEZ
VALDEZ's Avatar
i pulled mine out of an early to mid 70's van and fits great and doesnt hang below the bumper
VALDEZ
1971 C10 LWB 350/350
http://67-72chevytrucks.com/vboard/s...d.php?t=400327
VALDEZ is offline   Reply With Quote
Old 06-19-2011, 07:46 PM   #24
waybad
waybad's Avatar
chevy,ford van???
waybad is offline   Reply With Quote
Old 06-19-2011, 11:05 PM   #25
nikwho
nikwho's Avatar
I went with the '69 mustang fuel tank. the mounting flange is closer to the top of the tank and it fit very well! Only about $118 shipped! well worth it!
'68 GMC - BBC/TH400
