Old 04-06-2010, 08:18 AM   #1
C10Silverado79
Opinions wanted for brake update on 79 C10
hey gang,
I have a couple of questions for those with more brake expertise than I have. I am planning to update the brakes on my 79. I got the truck a month or so ago from my father-in-law and a lot of the parts are still original. I am not planning to 'upgrade' as much as just update to newer parts so that the system is strong and reliable. My plans at this point are:
FRONT
Replace hoses, calipers, pads
Turn Rotors (replace if necessary)
Pack wheel bearings
REAR
Replace hose
Replace Wheel cylinders, shoes, springs, etc
Turn Drums (replace if necessary)
Flush brake fluid during process.
Am I overlooking anything important?
Are there any particular components that I should seriously consider upgrading rather than replacing?
Is getting braiding lines worth the extra expense? I do plan on towing occasionally.
This is not for show. I just want the brake system to be reliable.
Thanks in Advance.
Steve
1979 C10 Silverado
1998 Camry 5spd
2005 Harley ElectraGlide
C10Silverado79 is offline   Reply With Quote
Old 04-06-2010, 09:39 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Opinions wanted for brake update on 79 C10
Since your just doing a stock rebuild, I don't feel braided lines are worth the extra expense. I would consider premium quality pads/shoes a worthy expenditure.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-06-2010, 02:28 PM   #3
C10Silverado79
Thanks for the feedback. Any recommendations on brake pads? I have the usual retail suppliers here. (Pep Boys, NAPA, Autozone, Advanced Auto) I can order online if there is a good reason.
1979 C10 Silverado
1998 Camry 5spd
Old 04-06-2010, 03:31 PM   #4
SCOTI
SCOTI's Avatar
Wagner or Raybestos products.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-06-2010, 08:03 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
x2 on the Raybestos. I also don't feel the braided lines are needed.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-07-2010, 11:14 PM   #6
C10Silverado79
I got a late start on the brake job tonight so I didn't get too far. Got the truck up on stands and the wheels off. Rear drums came off easy. Now I know for sure that I have the 2in drums. ( I was guessing that was the size but didn't know for sure)
I did a cursory check yesterday but didn't find anyone local handling Wagner or Raybestos brakes. I'll have to check a little more tomorrow. If it too much of a pain, I'll have to go with a premium set probably from NAPA.
Pulled the MC cap off and the reservoir for the rear brakes is almost empty. (oops - should of checked that sooner probably)
1979 C10 Silverado
1998 Camry 5spd
