another frame question
what all would i have to do to get my 62 body on a 88 frame?
60-66 Nut
Re: another frame question
I don't know as it is possible to do with good results......at least not without a ton of work. The '88 and up frames are a lot different than the earlier frames. I've got 30+ years fabrication experience and I wouldn't bother with it myself. Just find your self a '72 and earlier frame if your original frame is unuseable.
theres nothing wrong with the frame i have now. when i go to put my v8 in it how do i mount my trans crossmember? the frame gets really narrow where the drive shaft goes threw and there looks to be alot of little stuff right before the x member that i can get rid of. do you know the stuff im talkin about? if not ill post up a pic this afternoon.
#4 | |
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
#5 | |
60-66 Nut
Even though I haven't worked on many '60-'62's I'm well aware of what you're talking about. It is possible to put an auto trans in those frames. A lot of guys do, but the crossmember will likely have to be made. I know that Markb01 has pisted pics of his original auto trans crossmember here somewhere. You might send him a PM and see if he can show you where it is. That will at least give you an idea what needs to be done. Fabbing a trans crossmember and a few other things is a heck of a lot less work than trying to change to a frame like the '88 and up frames......or even the '73-'87's
Oh yes I do remember. I've been working on these trucks about that long as well. Back then they were pretty much overlooked. Years ago I was real pleased with what i had figured out would work. Now it is not so much of a mystery
I just built a crossmember for my son's 61. We are installing a TH350 behind a 350. I will get some pictures and measurments tonight.
thanks for the help guys
