Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-08-2010, 10:29 PM   #1
Shon
widest tire on 15x10
What is the widest tire one can fit on these 71 trucks on a 15x10 rim with stock width axles and lowered 4-5 inches. no spacers.
going to need meat but not going to cut the truck.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 04-09-2010, 12:06 AM   #2
Super73
Super73's Avatar
Re: widest tire on 15x10
Got a back space for us to work with?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-09-2010, 08:10 AM   #3
Shon
15x10 T'stars with 5.5" BS
Old 04-09-2010, 08:40 AM   #4
Hart_Rod
Hart_Rod's Avatar
Is it tubbed? IF not, I think a 11-12" is about as big as you'll get. Tub it like my 68, and the sky's the limit, . I currently have a 12" wheel with a 15.5, but I'm looking to go to a 15" wheel with a 18...
Hart_Rod is offline   Reply With Quote
Old 04-09-2010, 10:36 AM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
hey Rob I thnk we are stuck where we are with the 15.5's that tire will rub on the spring( see your second pic) or the bed..you pick..I have run the #'s and I can't make it work...check the section of the 18's and you'll see...the combo of the added 3" of rim and side wall bubble make it imposable with a stock suspention
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-09-2010, 10:37 AM   #6
Ackattack
Ackattack's Avatar
What kind of back spacing do those 12" wide wheels have? And do your tires tuck into the fender wells?
I tubbed my truck too, and I'm thinking while at the track, I need clearance for the tires to tuck on hard launches (plus I'm lowered anyways)
I was thinking probably about 8 - 9" backspacing for a 12" wide wheel.
Ackattack is offline   Reply With Quote
Old 04-09-2010, 11:22 AM   #7
Hart_Rod
Hart_Rod's Avatar
They have a 6" backspacing, which gives 7" out from the drum mounting surface (it's the wide rearend also). I'm about 6" lower than stock in the rear right now. I've got a couple more inches to tuck before their is any interference. I think with a 20" wheel and 29" tire that there would be less ballooning which would provide some additional clearance. How hard do you plan on launching?
R/
Old 04-09-2010, 11:27 AM   #8
Shon
As hard as it will with 100% throttle
Old 04-09-2010, 11:50 AM   #9
Hottrucks
Hottrucks's Avatar
heres a pic of my tires..this is slammed with a 2 1/2" c notch..these are 31x15.5x15 and I build the truck for 29's so they rub about 1/2" from full dump..my rims are stock rallies with 4" added to the back space ( dumb ass I never measured before I put them on) when I switch to radials it will all clear fine...my tubs are 4" wider..if you look at the stock tub I moved it one hole to the center
Old 04-10-2010, 02:13 PM   #10
Shon
Wondering if 325/50 DRs will work....
Tire Diameter 28.00 in.
Section Width 13.10 in.
Tread Width 11.60 in
Old 04-11-2010, 08:43 AM   #11
Hottrucks
Hottrucks's Avatar
your going to have to pick a tire size and build the truck around that..in other words how low and wide you want it to look..also if you you find an older (pre70) rear axle you will end up with a little narrower trac which will help with rubbing
maybe you need to take some measurements from what you have then we can GUESS on a choice
Old 04-11-2010, 08:48 AM   #12
Shon
I will just pick a tire that will fit and make it work.
only reason I mentioned the 325/50 is b/c a buddy had 2 sets i can use.
Old 04-11-2010, 09:01 AM   #13
Hottrucks
Hottrucks's Avatar
then I would grab one lift you truck up ( by the axle) take your wheel off and see how it looks and fits......since your not going to tub you can get a good idea and rotate your tires at the same time..???
Old 04-11-2010, 09:10 AM   #14
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
One thing that doesn't look like it's been mentioned is that certain width tired are designed to go on certain minimum width wheels. Just because the tire machine will get it on doesn't mean it's right or safe. In a perfect world, you want the edge of the tire tread to be parallel with the edge of the wheel. If you have a 12" tread width and a 15" center section on a 10" wheel. That is not good. Changes how the bead of the tire meets the wheel. really hard on the sidewall too and it will start to crack over time. Just a thought.
prostreetC-10 is offline   Reply With Quote
Old 04-11-2010, 11:59 AM   #15
Hottrucks
Hottrucks's Avatar
^^^^ Good point^^^^
Old 04-11-2010, 12:49 PM   #16
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
all true with todays lower profile tires. with a taller profile (70 up) you can get away with a wider tire/narrower wheel scenario...but not by much.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-11-2010, 04:25 PM   #17
SCOTI
SCOTI's Avatar
325-50's are a common size used on 10" wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-11-2010, 05:10 PM   #18
Shon
these tires do fit on the 10" rears per Manfucturer's rec but do they fit a 71 in stock form with T'star 5.5" BS
Old 04-11-2010, 06:10 PM   #19
SCOTI
SCOTI's Avatar
5-5.50" back-spacing is common to 71-87's for a 10" wheel. You need to measure your truck to be certain they'll fit. What fits one may not fit another; always verify your set-up.
What is currently on the truck?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-11-2010, 06:35 PM   #20
ratrod67
ratrod67's Avatar
I have ran the 315/60's on 2 trucks. I used a 15x10 wheel with 5 inch backspacing both times.
72 LWB
ratrod67 is offline   Reply With Quote
Old 04-11-2010, 06:36 PM   #21
ratrod67
ratrod67's Avatar
71 lwb
Old 04-11-2010, 08:28 PM   #22
KQQL IT
At the body shop.
KQQL IT's Avatar
hoosier d/r 325/50 on 10 doing work.
Old 04-11-2010, 10:44 PM   #23
Shon
currently using BFG 275/50/15 on 15x10 rally, this tire is not going to work with what I got planned, I am going to need more meat!
Old 04-12-2010, 06:44 AM   #24
Hottrucks
Hottrucks's Avatar
then your going to need a tub...
I'll bite
What are you planning???
Old 04-12-2010, 07:32 AM   #25
Shon
right now with no suspension mods and the 26" BFG DRs it doesnt like to be hit out the hole with the 100 shot, I can hit it about 30-40' out and it is fine so I will be going to 28" tall tires for looks and to get more meat and I hope to eventually put 150-200 shot from a Nitrous Outlet Plate system. And while doing all of this it will eventually have heads and cam plus a GOOD stall TC (yank or vig/PI). If I follow the recipe of the others cars I have been involved in, I should be able to make 475-500 to the wheels on motor.
