12-13-2009, 01:48 PM | #1 |
RHS BBC Heads??
Anyone here use a set of Racing Head Service bbc heads or have in the past? I am n on buying a set but don't know much about them. Thanks.
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
12-13-2009, 03:59 PM | #2 |
Re: RHS BBC Heads??
I have seen a few companies that use them and build some stout motors. I have only heard good stuff about RHS.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
12-13-2009, 05:13 PM | #3 |
Re: RHS BBC Heads??
Thanks rip! I just keep seeing these ads everywhere and i didnt know whether they were legit or not. I'm thinking about getting a set for the big block because i don't wanna spend the extra money atm for brodix, dart, or afr. Still debating though.
12-13-2009, 05:29 PM | #4 |
Re: RHS BBC Heads??
RHS = CompCams
It's good stuff. |
12-13-2009, 06:47 PM | #5 |
On a budget like Fred Sanford
Re: RHS BBC Heads??
Agreed....RHS makes great stuff. Pretty easy to squeeze 650hp out of a 454 with a set of their bbc heads.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
12-14-2009, 03:38 AM | #6 |
Re: RHS BBC Heads??
swb you just put a big SEG on my face. I likes the 650hp. Didn't know CompCams made RHS. I think i'll try a set but it's gonna be awhile. I come back from Iraq in late June so . I just need something to make the ole pickup outrun my paw's camaro's. Doubt i can though. The 96 runs 6's in the 1/8 and the 79 runs low 7's. Maybe a little juice will get me there lol. Thanks for the help. Still open for more suggestions or advice.
12-15-2009, 12:20 AM | #7 | |
60-66 Nut
Re: RHS BBC Heads??
Your sig says "Debating on building a 396" I would go with a 454 if you're wanting some go fast power. A 454 will make more torque which is what it takes to get a heavy truck moving. Top that with some RHS heads and as swb85 said, an easy 650hp.
Stay safe over there and thanks for your service Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 12-15-2009 at 12:21 AM. |
12-15-2009, 01:50 AM | #8 |
Re: RHS BBC Heads??
Hell, i have Dart heads (just as good or better) with a very tame cam and am pushing 500 ftlbs at about 3300 rpms.
12-15-2009, 03:12 AM | #9 |
Re: RHS BBC Heads??
yeah, my sig does say "debating on building a 396" but i havent changed it in a while lol. i just bought a 454 not long ago and had my dad pick it up. and to you who said "thank you for your service" i say "thank you for your support"
12-15-2009, 03:07 PM | #10 |
Re: RHS BBC Heads??
Are the RHS heads aluminum? If not You might want to look at the patriots. My buddy has a pretty stout 489 with patriot aluminum heads. On a truck you really need to lose that weight off the nose.
Be safe and thanks again for what you do.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
12-15-2009, 03:28 PM | #11 |
Re: RHS BBC Heads??
Okay, i'll look around for some patriots also. I bought my wife a 50" TV, $1000 worth of clothes, and a necklace for christmas... all because i'll have something to hold against her when i get ready to build the 454 maybe she'll find it in her heart to let me go crazy but i doubt it
12-17-2009, 03:59 PM | #12 |
Re: RHS BBC Heads??
I have RHS heads on my BBC, but it hasn't started yet. Here are some real pics for you.
12-17-2009, 04:02 PM | #13 |
Re: RHS BBC Heads??
Here are some ported pics and flow numbers also because I like showing off
12-26-2009, 06:41 PM | #14 |
Re: RHS BBC Heads??
I have a set on a 496.The engine I was coping made 625 and I can get about 10.5 mpg on a good day . Thank you for your service.
12-27-2009, 12:31 AM | #15 |
Re: RHS BBC Heads??
Sweet truck Hezie
12-27-2009, 07:54 PM | #16 |
Re: RHS BBC Heads??
This one is putting out 1100hp it has RHS heads.
uses 15 gallons to go 24miles plus a little more. Last edited by mbgmike; 12-27-2009 at 07:56 PM. |
02-22-2010, 09:49 PM | #17 |
ShortBus KingPin
Re: RHS BBC Heads??
I have a 505 with RHS heads. Hyd roller cam, 10 to 1, 93 octane. It made 668hp and 611tq. 6400rpms and 4400 rpms. They are unported.
02-23-2010, 10:48 AM | #18 |
Re: RHS BBC Heads??
02-23-2010, 11:55 AM | #19 |
ShortBus KingPin
Re: RHS BBC Heads??
04-09-2010, 04:06 PM | #20 | |
Re: RHS BBC Heads??
Edit: As cast 320's? Last edited by ulakovic22; 04-09-2010 at 04:07 PM. |
04-09-2010, 08:43 PM | #21 | |
ShortBus KingPin
Re: RHS BBC Heads??
Duration: Int. 308 Exh. 315 Lift: Int. 662 Exh. 688 Centerline. Int. 109 Exh. 114 Lobe sep. 112* 10.5 to 1 compression DART Single Plane 1000cfm Demon 2.25 headers with 3.5 mufflers
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) |
