#401 |
One day...
![]() Join Date: Apr 2008
Re: My 93 Crewcab Build
Yeah that would be about right though
![]() We can mod mine though cant we or is the one from the white truck a guinea pig one?
#402 | |
CHEVY ONLY
#403 |
One day...
Cool, ill see what i can find at the shop, if i get to the shack today ill haller at ya.
#404 |
Dude! I'm never around for the good fireworks. Glad you two have finally decided to quit talking. The less I have to read from Joesph, the better, lol.
Scott glad you got one down and several to go. Dad's got my number, so if you ever need any help towing or some help to tackle something, let me know. Congrats on getting the cable right. |
#405 | |
One day...
![]() Cool, yeah ill haller if i need something and same to you if you need something, i dont mind.
#406 |
#407 |
#408 |
Scott, have you had a chance to find the VSSB in the green one?
Do you know what gears the white truck had? I'm curious to see how the white trucks VSSB works in the green one. I called Radio Shack, they only have the 8-position DIP switches, we need 2 of 6-position ones. But I'm guessing we can make 2 8-position ones work. They are only about $2.50 each. You could get 4 and we can modify 2 VSSB's, I'm guessing you will need to calibrate one for the crew also.
CHEVY ONLY
#409 |
This message is hidden because joe231 is on your ignore list.
Check! |
#410 | |
One day...
Heck yeah i hope that it fixes it, at least the speedo isnt showing me going slower than i really am ![]() The white truck had 3.42's in it. Think i should just plug the one from the white one in the green one and see what happens? |
#411 | |
I'll run the numbers and see how close it should be.
CHEVY ONLY
#412 |
One day...
Do you need the numbers off the one i have?
#413 |
Nope, just the gear ratio and tire size. Was the speedo accurate with the 275/60/15 tires?
EDIT: I just checked it out. The VSSB from whitey should be good in the crew.
CHEVY ONLY
#414 |
So is your speedo good now?
You need a GPS to check it?
CHEVY ONLY
#415 |
One day...
I beleive that it is right, you have a GPS?
#416 |
Heck yeah! My phone has is all
CHEVY ONLY
#417 |
#418 |
One day...
cool, we'll have to check that out and see if its right.
#419 | |
![]() sure thing!
CHEVY ONLY
#420 |
One day...
Got the starter on it last night and fixed some more grounds and found a whole gasket kit for small and big chevy both unopened
![]() Going to get the manifold on it today, should be able to get the engine ready to start but just need the fuel tank brackets moved so i can mount the tank. |
#421 |
Sweet!
#422 |
One day...
Got the manifold on and starter wired up, took the seats out and cleaned it out a bit and put the seat from the 95 in the front and moved the other to the back. Not too much accomplished but its something
#423 |
CHEVY ONLY
#424 |
One day...
I knew that was coming
![]() Ok ok ill take camera out today or tomorrow
#425 |
Sorry, I couldn't help it
CHEVY ONLY
| Bookmarks |
