#26 |
Between Trucks...
Re: miss at slow acceleration and cruise
Beat it to fit, Paint it to match... ![]() |
#27 |
I think that you have a lean surge. Running lean causes the engine to run hot and could cause the plugs to get really hot and maybe what is causing the glow. Try tipping in the choke flap when running at 2000 rpm and see it the engine speeds up. If it does it is lean.
#28 |
72 chevys 4 life
thank you mertz ill try that tonight if i keep the edelbrock on long enough to mess with it. Im puttin a 750 double pumper on it once i go get it =)
I dont call it being young and dumb....I call it young and havin fun ![]() |
#29 |
S.D.M.F.
Ur timing is probably to fast. when the motor is cold is it hard to start?? i was having the same problem and i fixed it this morning by back the timing down.
EDIT: dont know about the plugs though
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() Last edited by longhorn396; 04-09-2010 at 01:41 PM. |
#30 |
72 chevys 4 life
ill try to retard it a little more i guess. And no it is not especially hard to start when cold.
#31 |
Big Red - Now its a SWB!
usually if it is too advanced it will start ok when cold then after it warms up it'll crank slow then fire.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
