04-10-2010, 04:36 PM | #1 |
Foolish Mortal
Wheel bearing tutorial?
My brother and I are trying to find a tutorial in case we need to replace the wheel bearings. I have an 1969 with the original drum brakes.
Can anyone point me to the resources? |
04-10-2010, 04:53 PM | #2 |
Re: Wheel bearing tutorial?
factory service manual// sold at pretty cheap prices by most board vendors
you can also check local library for a one size fits all service manual like chiltons,motors,haynes etc
04-10-2010, 05:01 PM | #3 |
pretty simple and straight forward, remove the castle nut lock pin, remove the castle nut, slide the drum off, pull the bearings. remove them, buy new ones, buy wheel bearing grease, pack the bearings with grease by working it in there with your hands, then reinstall opposite of how you removed it.
04-10-2010, 05:11 PM | #4 |
Between Trucks...
Get the Chassis Service Manual. There is a specified torque on the locknut to set bearing preload when you put it back together.
Beat it to fit, Paint it to match... |
04-10-2010, 06:41 PM | #5 | |
Oh, if it were only that easy.....4 simple words, that can take quite a while to impliment.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
04-10-2010, 07:27 PM | #6 |
Foolish Mortal
04-10-2010, 08:09 PM | #7 |
Between Trucks...
Is the truck a 1/2 ton or 3/4 ton?
04-10-2010, 10:52 PM | #8 |
my dad, who comes from a long line of mechanics, told me to turn the rotor(or drum) and tighten the castle-nut until you feel sligt drag on the rotor. it seems to work pretty good
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
