04-09-2010, 09:28 PM | #1 |
Kung Fu Master
Used Demon 650 carb
I have a used Demon 650 with vacuum secondaries that will need a rebuild. I took it off a running 84 with a 350 but I'm not sure the secondaries were working. Electric choke, however it would stick from time to time. Had it hooked to a 700R4 but I'm not sure the linkage was correct. At any rate, I ran it for over a year until I replaced with an edelbrock. AS IS $100 plus the ride. No PM's. I will try and do my best to answer any questions.
SOLD pending payment to FOREVER71, thanks
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 Last edited by WestButteTruck; 04-11-2010 at 12:39 AM. |
04-09-2010, 09:43 PM | #2 |
Re: Used Demon 650 carb
If that was a manual secondary I would have bought this right now good deal
04-09-2010, 10:31 PM | #3 |
ill take it pending a part# to verify its a 650 and shipping to 97080...thanks
04-09-2010, 10:45 PM | #4 |
If forever 71 passes, would you be interested in a trade? PM me if so, because I tend to forget where I post stuff. I have a carter AFB 750 , same as an Edelbrock. I also have several other pieces and parts you might be interested in.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
04-09-2010, 11:07 PM | #5 |
Kung Fu Master
I had to use the Barry Grant website and input some numbers.
http://www.barrygrant.com/demon/imag...tity-Speed.pdf I have a 6 cast into the top of the body and also the "downleg boosters" which comes out to the 650, VS on the side for vacuum secondary. There wasn't a part number on it anywhere else I could see. I spent some time a while back researching this and am pretty confident in my findings. FOREVER71, let me know if you are still interested. Is USPO o.k. for shipping?
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 Last edited by WestButteTruck; 04-09-2010 at 11:22 PM. |
04-09-2010, 11:55 PM | #6 |
postal is fine...could ya get me a pic of front , back and underside?...thanks...jeremy
04-10-2010, 12:10 AM | #7 |
Kung Fu Master
pics
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
04-10-2010, 05:12 PM | #8 |
hey, its weird that all the numbers arent there. im not sure about buying it due to the fact that i bought a 500cfm off ebay already,that was supposed to be a 650cfm. thats why i need the numbers. i dont want to buy a rebuild kit and find out it wont work fo one reason or another.....jeremy
04-10-2010, 09:28 PM | #9 |
Kung Fu Master
Did you check out the web address I posted above? Mine has the number "6" cast into the body, and it has the downleg boosters. Plug in the numbers, you get the 650. I'm convinced. I guarantee or your money back. There, it's in writing. If you don't want it let me know so I can move on to the next person.
EDIT: SOLD to FOREVER71, thanks
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 Last edited by WestButteTruck; 04-11-2010 at 10:56 AM. |
04-10-2010, 09:58 PM | #10 |
whats shipping?...pm me your address...ill get ya a money order...jeremy
04-11-2010, 01:23 AM | #11 |
mini truck racer
Put me in line . If it has a 6 on the air horn and down leg boosters . Should fit nicely in a Large flat rate box .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
