04-11-2010, 04:45 PM | #1 |
Are front brake pads to touch rotor all the time?
My front brake pads touch the rotor even when the pedal is not pressed.
Are they supposed to do this rather than wait off of the rotor until the pedal is pressed?
Old Smokey: 85 GMC 3/4 ton long bed crew cab originally a 5.7 gas engine now with an 84 6.2 with a 92 serpentine belt system, a banks sidewinder, torque converter, and a shift kit. I bought her this way from someone handy - and now am trying to figure out how all this truck works. The Old Smokey project: http://67-72chevytrucks.com/vboard/s...d.php?t=390518 |
04-11-2010, 04:48 PM | #2 | |
Re: Are front brake pads to touch rotor all the time?
Yes, they touch at all times, very little "pressure" is applied though. If you were to pull them away, the pedal would travel waay too far before anything happened.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
04-11-2010, 05:12 PM | #3 |
OK, thanks again LONGHAIR.
04-11-2010, 05:40 PM | #4 |
Yep - in addition, it also helps to keep debris off the rotors (keeps them clean).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-11-2010, 07:31 PM | #5 |
haha, ford guys...
might i add they will drag more as soon as new brake pads are installed. they take a few yards for them to "break in"
04-11-2010, 08:16 PM | #6 |
Thanks Kieth, now I see how that would help.
Thanks spinem, that clears up what the manuals meant when they referred their settling in.
