Old 04-11-2010, 06:36 PM   #1
87gmcsierra
87gmcsierra's Avatar
body work.
Ive never done body work and wanted to start on my 87 its got surface rust mostly so how and what would i use to fix this and any tips for a beginner? Thanks
87gmcsierra is offline   Reply With Quote
Old 04-11-2010, 08:27 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: body work.
Well, You can start by gandering around in this section;
http://67-72chevytrucks.com/vboard/f...splay.php?f=16
Do some searching first and if you don't find answers to your questions start asking there......
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-11-2010, 08:34 PM   #3
CenValyCali
Re: body work.
Start on one part of the truck. Pick a fender or a door and get to sanding on it. You don't have to take it to bare metal. I like to find the highs and lows and if I can get to them I'll hammer them out but if not a nice layer of bondo will work too. I like the stuff 3m has out, it's called sand blaster. Paint and bondo don't stick to the sandpaper so you can go a long ways with your paper. I just started using tape around areas that I need to bondo. I think it helps. You don't have extra bondo to sand.
CenValyCali is offline   Reply With Quote
