Old 04-13-2010, 01:55 AM   #101
highperf4x4
Re: 1969 GMC Short Fleet Build
Sweet!
highperf4x4 is offline   Reply With Quote
Old 04-13-2010, 10:52 AM   #102
djmachinist
djmachinist's Avatar
Originally Posted by VA72C10 View Post
You can get a nice aluminum radiator made to fit our trucks on ebay for around 300-400 and fans for 100-200 plus a controller for another 100. So for 500-700 you can get that setup....2K would be for name brand griffen or be-cool rad and fans but there are some cheap alternatives that board members have used and been happy with.
Thanks for the info, I called "Be-Cool" tech line, and I told them what I had. They gave me the following part numbers for a direct-fit alum radiator/with twin 11" fans/controller & hardware kit: No. 82058. also part No. 75095-air cond. relay kit. Be-Cool says this set-up is good up to 500HP engines. Summit racing had everything in stock, I should have it by thursday. Another issue put to rest!! Cost= $1400.00
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Old 04-13-2010, 02:16 PM   #103
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Dale, that thing looks good on all 4's. Money well spent.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-13-2010, 04:09 PM   #104
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Looks great. If I were you I might have to talk to the guy leaning against the truck though...
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-14-2010, 06:54 PM   #105
djmachinist
Bumbera's has finished most of the engine plumbing and throttle/trans kick down cables. The air Cleaner looks good.........
DALE JONES
Old 04-14-2010, 09:48 PM   #106
highperf4x4
That's gonna be too slick to drive!!!
Old 04-14-2010, 11:47 PM   #107
djmachinist
Nah, Its going to be a daily driver, thats why I did not chrome out the engine.
Dale
DALE JONES
Old 04-15-2010, 07:01 AM   #108
djmachinist
I checked the rear shock angle on the rear end, bounced the rear up and down, the shocks are not doing much dampening at the 35 deg. angle they are at now since I lowered the truck I guess I will order the shock relocator brackets from early and stand the shocks up more vertical. Also the Steering Column bearings are shot, real sloppy......Oh well, its only money...Ouch!!!!!..............but I'm having a good time
Dale
DALE JONES
Old 04-15-2010, 09:04 AM   #109
highperf4x4
Old 04-15-2010, 12:59 PM   #110
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Dale
That's something I learned all to long ago... you only live once right?
I hope because I've been spending my retirement fund like its going out of style, and I have 20+ years before I can retire.
-Nate
Old 04-15-2010, 02:22 PM   #111
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Neat build.....
She will be a great looking truck with all the modern bells and whistles when your done
Cole Trickle is offline   Reply With Quote
Old 04-15-2010, 06:31 PM   #112
big mike71
big mike71's Avatar
I won't be able to retire until they close the lid on my casket.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 04-15-2010, 06:38 PM   #113
big mike71
big mike71's Avatar
The Bumbera guys talked to me about the radiator and fan issue now that the engine and trans is installed. since I am also installing a Vintage Air System, they suggest a custom aluminum radiator with twin electric fans. The catch is it cost about two grand.....ouch!!!!! Any body have a alternative solution?
Thanks,
Dale
I have Vintage Air and a factory radiator with no overheating issues. How tall are your new tires?
Old 04-15-2010, 07:53 PM   #114
djmachinist
Mike,
28" dia. rear tires, 3.73 rear end.
Dale
DALE JONES
Old 04-16-2010, 12:21 AM   #115
djmachinist
Mike,
Another thought on why you are doing fine on your stock radiator set-up compared to my radiator needs here in houston.......I know it gets hot in the summer in Missouri however in Houston the average summer day is in the mid to upper 90's with 90 percent humidity. Heat transfer devices do not work very efficent in these conditions. What I bought may seem like a little overkill, but better safe than sorry. I grew up in the Dallas/Fort Worth area in North Texas. It gets darn hot there too, but the Humidity is on average about 40 percent. I have lived in Houston for twenty five years and have never got used to the summer weather down here!!!
Oh....Nate, Retirement, Whats that?!!!
Dale
DALE JONES
Old 04-16-2010, 12:44 PM   #116
djmachinist
Radiator install pics, Bumbera's did a great job installing the engine/trans/radiator components, the attention to detail is amazing with all the custom fabricated little brackets for the wiring and hoses!!! The radiator overflow catch tank came out nice!!!!
Dale
DALE JONES
Old 04-16-2010, 12:47 PM   #117
djmachinist
The new driveshaft arrived while I was there......Sweet!.....
Dale
DALE JONES
Old 04-16-2010, 02:58 PM   #118
VA72C10
VA72C10
VA72C10's Avatar
cool! Looking good and coming right along. You'll be enjoying it in no time!
Old 04-16-2010, 09:50 PM   #119
big mike71
big mike71's Avatar
Mike,
Dale
Thanks, I measured my truck, but not the tires. It is not lowered and it measured alittle over 31" in the front and alittle under 32" in the back.
Old 04-16-2010, 09:51 PM   #120
big mike71
big mike71's Avatar
Dale
Very nice setup.
Old 04-16-2010, 10:28 PM   #121
djmachinist
Mike,
My truck is lowered 2.5 in. in the front and 3 in. in the rear, measured from the top of the wheelwheels-31 in. in the rear & 30" in the front. I really do not want to lower it anymore.
Looks like your truck is just a bit higher than mine.
Dale
DALE JONES
Old 04-17-2010, 03:27 AM   #122
highperf4x4
Man you sneak alot of stuff in here while I'm not watching!!!
Looking sharp though!
Old 04-17-2010, 07:47 PM   #123
big mike71
big mike71's Avatar
Ok, I ordered Falken Ziex S/TZ-01 size P275/50R-17 for the rear and
P255/50R-17 for the front. I think this may work. Thanks for the Heads-up.
Dale
If I have a 9" wide rear wheel what size tire would about the same height as a 275/50 -17. Thanks
Old 04-18-2010, 06:52 AM   #124
djmachinist
Mike,
What dia of wheel are you using?
DALE JONES
Old 04-18-2010, 06:12 PM   #125
big mike71
big mike71's Avatar
17"
