Old 04-06-2010, 04:43 PM   #1
hawleykt
Quadrajet vs Edelbrock
question.....
doin a new carb with electric choke and intake setup
have the option of goin with the quadrajet or edelbrock...which do u prefer/recommend?
i can get the quad intake for 30 bucks with the EGR....or a nearly brand new Edelbrock intake w/o it for free....thing is like 130 new. so im kinda on the fence.
i value your opinions.
hawleykt is offline   Reply With Quote
Old 04-06-2010, 04:52 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Quadrajet vs Edelbrock
Nothing beats a good running quadrajet. Run one on the Edelbrock intake. Is that free intake a spread bore or a square bore?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-06-2010, 06:07 PM   #3
tucsonjwt
Quadrajet. Professional rebuild for me, since I am not competent to rebuild a carburetor. I have had 1 Carter, 2 Edlebrocks, 1 store bought rebuilt Quadrajet, 1 professional rebuilt Quadrajet. Ditch the electric (or hot air) choke. Get a good manual conversion and hook it up. Improve cold starts and save gas - shut off the choke when you want to, not when some inaccurate thermo coil wants to.
tucsonjwt is offline   Reply With Quote
Old 04-06-2010, 09:35 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
Originally Posted by tucsonjwt View Post
Quadrajet
Another Quadrajet fan here, I've had better luck and gotten better mileage/performance out of my home brew QJ's than any of the others.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-06-2010, 11:34 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Edelbrocks are easy to tune for novice mechanics. It's really down to preference.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-07-2010, 12:08 AM   #6
asphaltburner
asphaltburner's Avatar
Yo! FRANKENTRUCK runs a 600 Holley dbl pumper and a matching 2" spacer. I like going from larger, same-size primaries to opening smaller, same-size secondaries. With the Q-jet, ya run on smaller primaries, and open larger secondaries. More punch on acceleration, and better mpg due to the smaller primaries, but is your goal mpg or performance? I can perform with the larger primaries more and require the secondaries less with the "square bore",...who knows if that's better overall?
However, most carbs have always been the "square bore" design.
My Holley is a PITA to tune,...mixture is backwards compared to most, and limited to a very fine tune. My Camaro's Carter AFB is magnificent,...easily fine tuned from full rich to full lean, if necessary. Mixture is tighten = lean, loosen = rich, properly.
Both Q-jet and "square bore" are fun carbs, just different theories of operation.
Have fun and good luck!
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 04-07-2010, 08:20 AM   #7
82swampthing
82swampthing's Avatar
holley all the way, edelbrocks are paper weights
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 04-07-2010, 09:40 AM   #8
James McClure
One shot, one kill.
Gentelmen, most off you know I spent 33 years as a Chevy mechanic. I've seen it all I think. My vote goes with the QJ for a street vehicle. My vote also goes with Holley for race applications. The QJ can be a bear to set up propeerly, especially if eng size\power change. (EG swap from 305\165HP to a 350 or 400 at 300HP) But just running a stock one on the right eng they can't be beat for keeping a good balance between economy and power. They are factory calibrated to a certain application. After market is calibrated for a wider range of applications and as a result run to rich at one end and to lean at the other. I ran Holley carbs with great success drag racing. Real PITA to rejet but once set they did quite well on everything from 305 to 454. I would stay with the QJ.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-08-2010, 02:35 AM   #9
355bullet
355bullet's Avatar
Quadrajet all the way! i had crap luck with my Edelbrock carb, i sold it. But for some it works..
355bullet is offline   Reply With Quote
Old 04-08-2010, 11:34 AM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
For the street, I'll take a properly tuned Q-Jet over....... well, anything!
But on the track I'll still use a Holley DP.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-08-2010, 11:54 AM   #11
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
For Street use Qjet
but for pure race i would get a Predator
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 04-08-2010, 11:57 AM   #12
glock35ipsc
Hmmm, a Predator. I had forgotten all about those things!
Bob
Old 04-08-2010, 12:27 PM   #13
jchav62
1962 C-10
jchav62's Avatar
I have Edelbrocks on the '62 and the '65. They both run great, but they seem to run a little on the rich side. My biggest complaint about them..and it's discussed a lot on here, are hot starts. After the engine is run and them parked for a few minutes, they are a b!tch to start up. They seem to get flooded in the heat and you have to hold it to the floor to firing it back up. I have a quadrajet on my '73 on a performer intake...runs excellent and fires on a dime everytime...hot or cold.
As I said in my earlier post...nothing beats a good running q-jet.
Joseph Chavez
Old 04-08-2010, 01:00 PM   #14
82chevy350
82chevy350's Avatar
hmm i have that same problem jchav62 could this be fixed with a spacer?
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 04-08-2010, 02:58 PM   #15
jchav62
1962 C-10
jchav62's Avatar
On my '62, I have a 2" spacer and an insulated gasket. It's not as bad, but it still floods when hot.
Joseph Chavez
Old 04-08-2010, 03:11 PM   #16
GMC Guy
GMC Guy's Avatar
i'm running an edelbrock 1406 with a 2 inch phenolic spacer and 5 inch K&N filter, and it runs pretty dang good. always starts, hot or cold. and the electric choke works flawlessly. i do have the stock Q-jet sitting in a box and i'm wanting to put it back on. but i need an electric or a manual choke kit, and also the adapter for the square bore manifold. the only reason i went to the edelbrock was "bolt on and go" and the electric choke feature, which was really nice in the winter.
All in all, my vote goes to the Q-jet. i remember after i rebuilt mine, the thing ran like a clock!
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 04-10-2010, 12:40 PM   #17
hawleykt
im just fed up with searching classifieds for a decent used quadrajet....
Old 04-13-2010, 11:34 AM   #18
hawleykt
how lame would i be if i went against all that we just talked about and threw on an edelbrock because it would be easy for me to do with the whole bolt and go ...lol
i would prefer the quad...but seems it might be a bit more complicated for me....as I am a novice.
Old 04-13-2010, 12:32 PM   #19
Damien
Damien's Avatar
You would have to modify the carb linkage and fuel line too if you go with the edelbrock. Ask around at local engine shops and parts stores. There were only millions made and there are a lot of people that believe they are worthless.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-13-2010, 12:52 PM   #20
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
it looks like im in the minority here but i say screw the qjet go with the edelbrock.personally ive only had bad luck with qjet's and i hate them with an absolute passion.i was even given(well offered)both a free qjet and a free carter afb(same thing as an edelbrock basically)and i ran far and wide from the qjet.not sure why ive had such bad luck with them but after having 3 of them take a complete **** on me if im lucky and have it my way ill never deal with a qjunk again.ive only had this one carter but its never gave me one bit of trouble and hot or cold truck fired with relatively no issues.so im happy with it and will stick with it.even if you dont use an edelbrock go with a holley or anything besides a qjunk
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 04-13-2010, 01:03 PM   #21
hawleykt
how so?
Old 04-13-2010, 01:49 PM   #22
manimal
manimal's Avatar
You can look into Jet Performance Carbs, they do awesome Q-Jet rebuilds, or get a Q-Jet from Edelbrock. I do NOT like the AFB style carbs from Edelbrock at all. I run Q-Jets on everything that is not F.I. Even my '77 F250 w/ 460 has a GM Q-Jet runs SWEET!
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-13-2010, 02:05 PM   #23
355bullet
355bullet's Avatar
a friend of mine that works on streets rods that have that problem with edelbrock carbs told me he installs a fuel regulator and it corrects it.
Old 04-13-2010, 05:22 PM   #24
Slofarmtruck
I am a +1 for the Edelbrock only for the fact that I know nothing about the Qjets. I just threw an Electric Choke Edelbrock 600 on my 305 that sat for 10 years, changed the oil, primed the carb and the motor ran like it sat for a day only. A few minor and simple tweeks later and she performs great every day. Please note that my Qjet had more leaks and loose bushings than I cared to attempt to repair compared to the ease of bolting on the Edelbrock. I had to use a longer peice of rubber fuel line for the Edelbrock and retained the stock accelerator cable and TV bracket.
Slofarmtruck is offline   Reply With Quote
Old 04-13-2010, 07:43 PM   #25
Damien
Damien's Avatar
Originally Posted by hawleykt View Post
how so?
You will need to get the correct stud or ball for the throttle and kick down cables to connect to. The fuel inlet on a Edelbrock is on the side at the rear versus front for the Qjet.
