05-14-2003, 09:52 AM | #1 |
How low should it go??
Quick poll type question....I want to lower my '69 SWB C-10 from original height using new springs front and rear. I want the truck to look like it's been dropped a few inches, but don't want the frame on the ground; Vermonts frost heaves and potholes would kill a low truck fast! I'm planning on running 15" Rallye wheels with tires somewhere around 275-60-15's; a set of rubber that is wide, but still has substantial sidewall height. What would you recommend the drop be for optimal appearance. I don't want the tires to disappear into the wheelwells, but also don't want a 5" gap between the tire and wheelwell. I've heard everything from 2", 4" to 4" 6" front-rear drop. Any suggestions?? I want the truck to look about like the below when done. Thanks all....
05-14-2003, 09:59 AM | #2 |
Seņor Member
That pic looks to be about a 3/5" drop.
05-14-2003, 10:17 AM | #3 |
Almost Satisfied
Go to Early Classics Web site and look at their stance photos. Those will help you choose and the truck they have in the photos has rally wheels and all.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-14-2003, 10:50 AM | #4 |
Resident Curmudgeon
VTKidder, where in VT are you? My location is in my signature, I have a few sheetmetal parts if you need anything.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
05-14-2003, 07:15 PM | #5 |
My truck has been lowered using ECE spindles and another companies springs. I think it is about 4" in the front. I am running 245/60's on the front. Look at the ECE site http://www.earlyclassic.com/catalogpg6.html. They have pics that show all of the different drops. The lower you can go the better.
http://photos.yahoo.com/cruzn72@pacbell.net |
