Old 04-12-2010, 10:59 PM   #1
JHP1967
Headers for Big Block in 67'
What are the best fitting headers for a 67 with a 454?
JHP1967 is offline   Reply With Quote
Old 04-13-2010, 08:59 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Headers for Big Block in 67'
I think it depends on some variables, like what motor mounts you used and the position on the frame they were bolted to. Also what kind of starter and if it is a manual or automatic transmission.
I have found that a mini starter is necessary with a big block and headers from recent experience.
I am sure some one else will chime in with more info.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-13-2010, 09:35 AM   #3
Fitz
For my '67 I used Sanderson C6's. It's a 572 with 67 -71 396 motor mounts. Trans is a Turbo 400. No need for a mini starter but the oil filter will need to be relocated using a remote filter setup. These are full length headers and tuck up into the frame so none of the exhaust is visible...helps cause I dropped my truck using an ECE 4/6 drop kit. The C6's fit 396, 454, 502 & 572.
Fitz is offline   Reply With Quote
Old 04-13-2010, 10:56 AM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Did you have to notch the frame?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-13-2010, 12:08 PM   #5
Fitz
Very small half moon notch 3/8 in deep and 3 in long on top frame rail only on passenger side for #4 cylinder tube. See photo. Last photo shows why you need to relocate the filter...just no way to get it out once it's spun off.
Old 04-13-2010, 07:58 PM   #6
JHP1967
I am going to have to get with PO ad see what motor mounts were used on my truck. Thanks for the help!!!
Old 04-13-2010, 08:58 PM   #7
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
I'm running Hedman #69110 on my truck w/'73-'87 engine mounts. I did have to clearance the frame rails both above & below on both sides, but I chalk that up to my running a tall deck. I have no issues with the oil filter location even though I'm running a GM oil cooler adapter that drops the filter 3-4". I am also running a later-model 454 gear reduction starter.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 04-13-2010, 09:34 PM   #8
handsomerob
handsomerob's Avatar
I'm using Headman 69130 on a 72 C20 with a 572 in it. I had to notch the passenger side frame rail both top and bottom to clearance the header. These are 2" primaries into 3" collectors.
handsomerob is offline   Reply With Quote
