Old 04-13-2010, 10:12 PM   #276
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Air Ride Install - '69 Chevrolet SWB Stepside
gang,
been a while, but I've been working on things; mostly on designs for the raised bed floor. not as easy as I thought, especially when I'm trying to make the bed floor look 100% stock and 100% aged. ran over to LMC and bought all of my bed bolts in regular steel. to get the rust on the heads as the original carriage bolts, I am blasting the heads, dipping them in an alkaline solution, and letting them set out in air. sounds like a lot of work though just for the patina-ed look, so that one is still being mulled over.
I'll post up the first step of the bed going back on as soon as my metal gets in and chips are flyin'...............
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-13-2010, 10:19 PM   #277
sourkraut
sourkraut's Avatar
have you concidered using the acid to rust/patina them and then after the acid put a clear on to seal them so they dont ust anymore, stuff works great!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 04-20-2010, 07:51 PM   #278
drewfever1020
did u relocate your front shocks or did u just slap on anothershock?
im looking to go with the same setup as u i like it alot
drewfever1020 is offline   Reply With Quote
Old 04-20-2010, 09:38 PM   #279
69CST-V
69CST-V's Avatar
If you have bare metal you should use vinegar and salt to get the rusted look.....it will do less damage than an acid to the metal and can be sealed when you get the desired result without worry of acids that will remain in the pours of the metal that you can't neutralize....
The build looks great can't wait to see it driving in the metro...
69CST-V is offline   Reply With Quote
Old 04-20-2010, 10:23 PM   #280
tcb-1
tcb-1's Avatar
nope, I didn't relocate the shocks. matter of fact, when I'm aired completely out I still have a whopping 1/8 of travel!!
Doug
Old 04-20-2010, 10:29 PM   #281
tcb-1
tcb-1's Avatar
oh btw, the bed is ON!! I still haven't raised the floor, but I at least wanted to get the bed mounted so I could mock up the raised floor supports. pics and details are coming, I just need to get one of the bed support rails media blasted, painted, and mounted.
pics on the way in the next few days, floor or not!
Doug
Old 04-20-2010, 11:05 PM   #282
drewfever1020
ok thats good to know ill probly be coping a pare of those monroe shocks u got for the front.
what about the back did u relocate them or just put drop shocks?
Old 04-20-2010, 11:11 PM   #283
tommyd241
tommyd241's Avatar
I absolutely love this truck. Can't wait for some new pics of the raised bed, as well as some pics of some steelies.
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 04-21-2010, 01:53 AM   #284
Jeffs70
Jeffs70's Avatar
I am curious to why you must raise the bed floor if you did not channel the frame at all other then a C-notch and Notching the support just above the rear pumpkin?
Jeffs70 is offline   Reply With Quote
Old 04-21-2010, 08:15 AM   #285
tcb-1
tcb-1's Avatar
I bought the Early Classic rear shock relocators and went with a set of different shocks. take a look on previous pages, I believe I listed the shock I went with.
Doug
Old 04-21-2010, 08:21 AM   #286
tcb-1
tcb-1's Avatar
I want to have a completely flat bed floor instead of either (1.) a hole in the floor or (2.) a fabricated hump for the differential.
like I've said in previous posts, I want to look inside the bed and it look COMPLETELY original. no fabbed metal, no unfinished holes.
Doug
Old 04-21-2010, 10:25 AM   #287
crakarjax
crakarjax's Avatar
Easy, just chop the top of your pumpkin off
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-21-2010, 01:44 PM   #288
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Okay Doug... we need some pictures of at least something. I'm chomping at the bit on not seeing any freshly updated pics of that clean beast.
At least post up some pics of the new mower in action...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-21-2010, 04:20 PM   #289
Jeffs70
Jeffs70's Avatar
ok makes sense, I wasn't sure if the pumpkin had traveled that far up above the floor
Old 04-21-2010, 05:13 PM   #290
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 04-21-2010, 09:23 PM   #291
tcb-1
tcb-1's Avatar
Nato and Rob, my two buddies! don't worry, I'm busting my butt to satisfy your pic fix!! you know it has to be just right to show you all!!!
Doug
Old 04-22-2010, 05:39 PM   #292
Jeffs70
Jeffs70's Avatar
hell yeah your doing a great job. your work is clean and perfect in my book, very helpful also.
Old 04-23-2010, 02:28 PM   #293
drewfever1020
pics!pics!pics!
Old 04-24-2010, 03:51 PM   #294
tcb-1
tcb-1's Avatar
had a few minutes to bring it out of the garage this morning, before a torrential downpour
well here's the beater riding on air, albeit she's aired out now!
still need to torque everything down, run the wiring for the taillamps, and install the tail gate. the bed wood isn't in yet, but at least you can get an idea of where we're at today. the next steps will be the floor design, but at least I CAN DRIVE IT!
if I haven't yet, I like to thank Keith (lolife99) and Jared (grimss) for their help when I started this project. here are two class acts that gave me great advise and insight. also, thanks to all of you, my extended family, for coming by my thread and looking, posting, whatever!!!
I get some more pic once the weather clears and the tank is full!!!!
Doug
Old 04-24-2010, 04:17 PM   #295
OARNGESI
OARNGESI's Avatar
That looks great
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-24-2010, 05:38 PM   #296
PipsC10
PipsC10's Avatar
have never seen a stepside that made me say wow, until now. That thing is spot on, great job.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 04-24-2010, 06:28 PM   #297
sourkraut
sourkraut's Avatar
doug have you decided on wheels? just my 2cents leave'm on! dude that thing looks perfect with the stance and the wheel tone a shade or 2 off from the body! i love it!
Old 04-24-2010, 07:08 PM   #298
drewfever1020
why doesnt it look low well it does but i thought it would look lower!
Old 04-24-2010, 07:17 PM   #299
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome work Doug!
That is what I'm talkin' about...
-Nate
Old 04-24-2010, 07:31 PM   #300
bobbo
bobbo's Avatar
THANK YOU! Looking great! Can't wait to check it out in person!
Robert
Life Member
1969 1500
Norwood, MO 2007
