Old 04-09-2010, 08:55 PM   #1
68 c10 ls2
68 c10 ls2's Avatar
New Dyno Numbers!!!
I sent my motor to a dyno shop and they got back to me with the numbers today. 696hp/651tq on E85 and 575hp/536tq on 93OCT (at the crank). . 02 LQ4 stock botom end (exeped fo new rod bolts), cam 224/230 .612/.612 (leading edge performance), Patriot 243 Stage 3 heads and a Maggie (new style/center inlet and some pulley switching) 112 running 12psi ( for E85) 9psi (for 93).
68 c10 ls2 is offline   Reply With Quote
Old 04-09-2010, 09:10 PM   #2
darthwall
Re: New Dyno Numbers!!!
thats what I call a daily driver lol
darthwall is offline   Reply With Quote
Old 04-09-2010, 10:27 PM   #3
68 c10 ls2
68 c10 ls2's Avatar
The truth is that it is a going to be a daily driver. Thats why i had 2 pcms made (1 for E85 and 1 of 93OCT).
Old 04-09-2010, 10:55 PM   #4
kyull67
kyull67's Avatar
nice! Can we get some Pics?
kyull67 is offline   Reply With Quote
Old 04-10-2010, 12:39 AM   #5
ShredSled
ShredSled's Avatar
Excellent! I bet you're stoked to get that thing in and go!
So what c/r are you at now with the smaller chamber on the 243 heads?
I don't think you'll have a problem with it, but you should have gone with '05+ LQ4 or LQ9 rods as they are beefed up...
Also just curious, how have your IAT's been? I've heard quite a few people complain about insane IAT's with the maggie 112...
I'm currently building up an LQ9, but really torn if I want to boost or not (wallet says no right now, haha!). I was leaning more towards a single front mount turbo... And looking at going with L92 heads.
get it!
ShredSled is offline   Reply With Quote
Old 04-10-2010, 01:39 AM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
That thing is gonna be a beast! When are you dropping it in?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 04-10-2010, 09:44 AM   #7
badriv455
'67 Chevy C-50
badriv455's Avatar
Did you get those figures mixed up? I would think that 93 oct would make alot more power than E85.
Bad Riv
'67 C50 Flatbed Dump
'98 Z71 Ext. Cab
badriv455 is offline   Reply With Quote
Old 04-10-2010, 10:27 AM   #8
LONGHAIR
Probably not...the alcohol of the E-85 has a much higher octane rating, so it will stand a lot more timing and boost. It takes quite a bit more volume of fuel to make that kind of power though.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-10-2010, 10:41 AM   #9
68 c10 ls2
68 c10 ls2's Avatar
the c/r is 10.0:1. I know i should have upgraded a few other parts like the rods and pistons but this is just a daily driver and will rarely be push to its max. I don't have the exact # for IAT's but my buddy builds a spacer that goes in between the intake manafiold and the blower and on his setup it dropped the temp by 30*.
Old 04-10-2010, 10:47 AM   #10
68 c10 ls2
68 c10 ls2's Avatar
The numbers are right. Like "LONGHAIR" said E85 will take a lot more timing and boost. I went with E85 instead of race gas because in live in MN and we have a lot of E85 stations and its way cheaper than race gas.
Old 04-10-2010, 12:55 PM   #11
badriv455
'67 Chevy C-50
badriv455's Avatar
Does anyone know what the actual octane rating of E85 is? We dont have a lot of E85 stations around here but about as many stations sell race gas and if we could substitute E85 for 110 race gas at about half the price that would be tempting. Probably have to build the carb for it though or get an alky carb
Bad Riv
'98 Z71 Ext. Cab
Old 04-10-2010, 07:09 PM   #12
68 c10 ls2
68 c10 ls2's Avatar
I think the OCT rating for E85 is 116. You can now buy E85 carbs from Summit or Jegs that are ready to bolt on. You also my need to put a bigger fuel pump in to keep up for the extra fuel that demand.
Old 04-11-2010, 04:22 AM   #13
ShredSled
ShredSled's Avatar
gotcha, thanks for the reply. 10:1 just puts you up to the same as the LQ9, not bad. But now I'm wondering why you went with the 243's then? Got a better deal on them instead of working the 317's???
I'd like to see more on that spacer too!
get it!
Old 04-11-2010, 09:57 AM   #14
68 c10 ls2
68 c10 ls2's Avatar
The 243's offered more compresion and better flow with bigger valves than the 317's. To have the 317's cc'ed and all that good stuff was about $1000. I picked this brand new Patriot Stage 3 heads up for $800. So it kinda was a no brainer.
Old 04-11-2010, 10:45 AM   #15
ShredSled
ShredSled's Avatar
yep $800 would seal the deal, couldn't get much work done these days on any heads for that price!
I'm a bit rusty on my memory right now, but I thought for sure the 317's had the same valve size and shape and flow #'s as the 243's and 799's??? Basically the same casting, just larger volume, and yeah, with the LQ4's pistons, lower c/r... I'm pretty sure that is the case, but either way, moot point here!
get it!
Old 04-11-2010, 01:12 PM   #16
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
9 psi vs 12 psi is quite a difference. couldn't you just run a meth injection kit and stay with the 93oct, but still be able to run the smaller/higher boost pulley? And if so...wouldn't this combo likely make more power then the E85 at the same boost level?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-12-2010, 08:24 PM   #17
68 c10 ls2
68 c10 ls2's Avatar
Well after digging through some old Hot Rod magazines and reading an artical on a "750 HP BLOWN 6.0L" its time to send my motor to a new tunning shop!!! I got almost the same setup and Hot Rod got 683hp on 93. This may sound dumb but 575 ins't enough!!! I know it could do a lot better. 100hp difference!!! Well i already got way to much money into this motor mine as well spend a little more to get it to its full power level.
Old 04-14-2010, 02:10 PM   #18
ShredSled
ShredSled's Avatar
I didn't read the Hot Rod article, but were they going for extreme peak numbers?
Those 683hp on 93 might not be quite as usable on the road as your 575hp either, but I don't know what either power curves look like either... Might be something to think about. Whichever has the flatter curve could actually be funner, even if that means it has a lower peak...
Also, were they using meth injection like 68GMCCustom was talking about above??
get it!
Old 04-14-2010, 02:21 PM   #19
Shon
NICE, looking forward to seeing RWHP #s!!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 04-14-2010, 02:29 PM   #20
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Its a good start.....
I was making about 475rwhp (550 @ crank) on a stock LS1 in my 04 vette with the 112 maggie on 91 octane. Standard pulley with custom tune,intake and exhaust.
At that amount of boost with heads and cam I would expect a little more.(not a whole lot if its a safe tune)
Not sure iif you have done it yet but make sure you pin the crank.
Cole Trickle is offline   Reply With Quote
Old 04-14-2010, 07:24 PM   #21
68 c10 ls2
68 c10 ls2's Avatar
I couldn't even get the 425hp to hook up (in 1st gear) with the long bed, so 683 right now would never get reached to the wheels/the ground. I just looked at thier dyno #'s and it looked good no flat in the curve. No meth just 93 to get 683hp, on the meth they got 751hp.
Old 04-14-2010, 07:28 PM   #22
68 c10 ls2
68 c10 ls2's Avatar
Yup after watching HOT ROD TV and saw them do it to the 10 camaro i ordered the parts that day to pin the crank.
Old 04-14-2010, 07:30 PM   #23
handsomerob
handsomerob's Avatar
you'll also need to run plastic lines etc. Anything over 15% E85 will start to deteriorate a stock fuel setup. Eats into the steel lines etc.
Quoted from a source online:
"the problem is that "Ethanol fuels with low moisture content will corrode the internal surface of the fuel rails." In layman's terms, ethanol causes pinpoint leaks in the fuel system;"
handsomerob is offline   Reply With Quote
Old 04-14-2010, 07:32 PM   #24
68 c10 ls2
68 c10 ls2's Avatar
I'm scared to put it on a dyno in the truck. All a have is a stock 4l80e in it and i know that if i throw those numbers at it, it will throw $$$$$$ (blow up the trans) at me and my truck fund ran out all ready.
