04-15-2010, 12:48 AM | #1 |
01 dash lights wont come on
i got in my truck tonight (2001 silverado z71) and as i took off i noticed that my radio wasnt lit up but it was still playing just fine and all the buttons worked, then i noticed that the guage lights wernt on. i turned the truck off and put the the key in the on possition with the e barke off, the clock on the radio was on but still no dash lights, when i turn the key to run the clock goes out too. what could be worng, a fuse? dimmer switch?
i did just replace my RF ABS wire and sensor but they worked fine after that.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
04-15-2010, 03:23 AM | #2 |
Ridin' Dirty
Re: 01 dash lights wont come on
I had almost the same thing happen on my 02 Burb. I was told by GM that it was the ignition switch inside the column. When it happened to me, I lost dash lights, all my gauges went to zero, and my transmission wouldn't go into overdrive. Apparently theres a power wire running through the ignition switch that powers a whole bunch of stuff. I noticed that it only happened when I moved the tilt steering up and down, and it was an intermittent problem. Thanks for reminding me, I still got to fix that..
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
04-15-2010, 03:27 AM | #3 |
Ridin' Dirty
Funny you should mention the ABS. I also started having an issue with my ABS about the same time as the other issue.. My issue was the ABS pump continuing to run with or without the vehicle running, so I unplugged the harness off the ABS pump.
