Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-10-2010, 08:39 PM   #1
wwhijr
SUPERscrapMAN
wwhijr's Avatar
95 TBI 4.3 to vortec swap
About 4 months ago I picked up a 95 S10 with part of a 4.3 in it. The vin shows it was a tpi truck. The truck was repoed evidently while the PO was doing some work on it. Since the body is in exceptional shape I kept it and figured I would find an other engine later. And last week I stumbled into a 92 Blazer with a 4.3 vortec in it.
What will it take to swap the vorte engine into the little s10. I figure it will need a vortec computer. I know the blocks will swap over but the electronics have me bit cornffuzzled.
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride
Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder
The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles
The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis.
wwhijr is offline   Reply With Quote
Old 04-10-2010, 11:01 PM   #2
Damien
Damien's Avatar
Re: 95 TBI 4.3 to vortec swap
wiring harness, intake manifold, intake ducting/ air box for a '95 CPI, fuel pump, fuel lines throttle and kickdown cables. The distributors didn't change until sometime during the '95 model year, so that will be fine. I think the wiring harness should probably come from a '95 too. I think if you had a parts truck of the same year it would make the swap a lot easier and cheaper. How much of the engine did you get? You could put the TBI on the CPI block. If you would rather stay TBI, I can help you out with parts.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-11-2010, 08:10 PM   #3
wwhijr
SUPERscrapMAN
wwhijr's Avatar
Unfortunate3ly I didn't get the tbi intake with the truck., It would have made things a lot easier I had I know. All that is in the truck now is the block that appears to be full of water and badly rusted. Guess I will have to troll Pull a part for a tbi or go ahead and find a v8 for it.
Old 04-12-2010, 02:11 PM   #4
Damien
Damien's Avatar
I have a complete TBI engine I just pulled from a '95. The long block is going to be used in a CPI truck, so if you need the intake "assembly" we could work a deal. If you need the computer or any wiring I have that too.
Old 04-13-2010, 02:42 PM   #5
Tink
Tink's Avatar
If possible, I'd put the whole drivetrain from the 92 Blazer into that 95... The CPI has more power and 92 is the 'golden' year - the only year you could get a CPI with a non-computer controlled auto. GM wiring harness's tend to have a lot of similarities, and often you can plug and play with a few minor lengthening/splicing. OR you could get a computer for a 95 CPI. IMO, I'd check all that out.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 04-15-2010, 04:35 PM   #6
wwhijr
SUPERscrapMAN
wwhijr's Avatar
How much we talking about?
