Old 04-15-2010, 05:41 PM   #1
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Custom Offset Steel wheels
Hey guys, I'm looking for some steel wheels that I can put some hubcaps on. I need them about 10 or 12 inches wide with a custom offset. I checked Wheel Vintiques and US Wheel, but they don't have any in 6 lug. I really want to keep the six lug bolt pattern. Any ideas? Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 04-15-2010, 06:06 PM   #2
low79fx
Re: Custom Offset Steel wheels
Try Stockton Wheels.
low79fx is offline   Reply With Quote
Old 04-15-2010, 06:27 PM   #3
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Stockton wheels made mine.
GGinferno is offline   Reply With Quote
Old 04-15-2010, 07:05 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
You might also try RallyAmerica. They've received good press in a couple of threads where I've seen them mentioned:
http://www.rallyamerica.com/hotrod_trucks/index.html
They also sell used wheels, so they no doubt have the 6 lug centers:
http://www.rallyamerica.com/usedwheels/chevy.html
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-15-2010, 07:12 PM   #5
Rannos
Rannos's Avatar
Wheel Vintiques have the pre 71 ralley wheel for our trucks in 6 lug in 15x12. They have the 5 small slots in them but otherwise are the same as plain steel wheels. You can order them in various back spacing from them as well.
Rannos is offline   Reply With Quote
Old 04-15-2010, 08:03 PM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
If you have access to a welder, possibly you could purchase a set of white spoke rims 10" wide and cut out their centers. Cut the rings off your stock 6 lug wheels and weld your centers onto the 10" rings. Mount them on your rear axel to true the centers so they turn without a wobble.
I cut the original 16" wheels in half added a piece of flatstock to make the wheels 9.5" wide, then reinstalled the original center for my 63 C10
I'm doing a set of 17"x 6.5" for my K10 project, converted from the 17.5"x5.25 original wheels.
Old 04-15-2010, 10:34 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
that ralleyamerica is a good place to go through, if you go to the h.a.m.b. at all, contact wheelkid over there, they should be able to make you a set.
Old 04-16-2010, 12:10 AM   #8
TheDark1
TheDark1's Avatar
Thanks guys, this is exactly what I was looking for.
GGinferno, how wide are your wheels, and is the rearend shortened?
1997 Formula WS6
Old 04-16-2010, 01:39 AM   #9
wild one
Registered.........
wild one's Avatar
Thumbs up Re: Custom Offset Steel wheels
with the above statements, I has a pair of custom offset 10" wide stock centered steel wheels made for the rear of my panel, they will have 295/50R15 tires on them once I decide on a color. Gary and son over at Rally America are great guys that do great work with a fast turn around time. They also stand behind their product 100%, I wouldn't hesitate to use them again!
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
