Old 04-15-2010, 11:04 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Br3w City's Project omgwtfbbq
If you've linked here from my YouTube Channel or other social media sites, welcome to my build hosted here on 67-72chevytrucks. tweet @wtfrevj or IG @rev_j_hd
IF THE IMAGES APPEAR DEAD LINKED OR BLOCKED DUE TO PHOTOBUCKET, PLEASE USE A BYPASS ADDON FOR YOUR BROWSER TO SEE THE IMAGES!!! FIREFOX AND CHROME EACH HAVE A FEW AVAILABLE, THE ONE LINKED BELOW WORKED FOR ME
https://outgoing.prod.mozaws.net/v1/...giikdkpmcpkaon
I'm not affiliated with this link and take no responsibility for the use of the addon. Only putting the link because it worked for me, and I want everyone to see my build!!
We're over 20 pages into it now, but this is the beginning.
Welcome to post #1 for...
THE H8RDCPTR. (i put the omgwtfbbq as a placeholder thinking i could change it...oops)
I was lucky enough to be given most of the original paperwork tracing the trucks history. Started its life in Oklahoma, and spent some time in Georgia and Florida before coming up to WI. I have the original metal service tag and owners manual somewhere too.
Started with a 66 short-step with a small back window. The truck was in pretty decent shape or so it seemed. Had a metallic green re-paint in the 80's, some rust that I could see but nothing horrid. Had a different hood since the original had been destroyed by time/rust.
The interior was mostly clean, gas tank removed and seats replaced with a later model bench seat. Newer wheel replaces the original also.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-15-2010, 11:19 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Br3w City's Project omgwtfbbq
Some more details on the project; It has a newer front suspension (newer style truck suspension i believe) lowered 4" and manual disc brakes and power steering.
The front also sports a 1-1/4" swaybar setup.
The rear is approx 5-6" lowered, with a small notch to clear the axle.
Nitro drop shocks all the way around.
Truck rear end with 3:73 posi, moser axles.
Mickey Thompson aluminum wheels.
The motor is a small block 355;
Scat cast crank
2.02 heads with the bowls polished
Comp Cams 4wd extreme cam
Weiand Sportsman manifold
Holley 670cfm Street avenger carb
Aluminum drive pulleys
Be-cool radiator / electric fan
Hooker Super-Comp headers to 2" true dual stainless exhaust.
Fabbed aluminum 13 gal fuel cell.
k&n filter setup.
It's backed by a 700r4 trans, Hurst shifter and mild stall (can't remember which one)
Old 04-15-2010, 11:36 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
First step after the basic maintenance was to start rust control, body repair and trying to uncover WHAT is hidden under all that paint.
Brought home the welder and decided to start by filling some holes in the bed rail (p.o must have had a cover on it at some point).
Hidden under the paint were even MORE holes, aside from the 40 small ones, a few of these bigger guys were in there. Looks like they had been filled with some sort of foam and then painted right over.
A few minutes with the welder, and some quick rattle primer and it looks MUCH better.
Old 04-15-2010, 11:54 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Started on my fenders, which actually was a happy surprise. After taking the paint down, I found the the major rust was only about 5", the rest of the surrounding metal was clean and rust free. I trimmed the bad stuff out leaving a nice square hole in the fender.
Got my patch made and started the welding process....yikes I'm rusty. I haven't welded sheetmetal in probably 3 years, wire setting are a *****.
I did manage to get a nice clean patch after all was said and done, time for the filler!
Old 04-15-2010, 12:01 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
While the filler was setting on that patch, I moved on to a "small" ding on my door.
It started no bigger than a quarter, but after some sanding...it kept going. There was nice baseball size dent and some wrinkles surrounding it, almost looked like someone was going to repair it but gave up.
LOOK AT HOW THICK THIS SH!T IS! And thats not even the deepest part.
Got the inside door panel off and started with the hammer and dolly to straighten it out.
Now that I had it much closer to where it should be, I could start with some filler.
Soo much straighter now
Straight like it should be!
Old 04-15-2010, 12:03 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This weekend should yield more pics as the stripping process continues. I have also removed the reverse lenses, and sunk the tail light cups into the fenders for a cleaner look...stay tuned.
Old 04-15-2010, 08:36 PM   #7
aerotruk63
aerotruk63's Avatar
What will he find around the next corner? Stay tuned....
Kinda like a paleontologist on his first dig. Having fun?
Old 04-16-2010, 09:25 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hahah ya. Most of the truck is actually fairly solid, it seems like the p.o. did more damage to it then nature did. Hopefully I should be able to finish stripping the bed this week so I can start to fill those holes in the bed rail, and clean up the tailgate etc.
Most of my previous sheetmetal experience has been with newer S10's, trucks etc..working with this nice thick american metal is a relief
Old 04-16-2010, 12:23 PM   #9
protrash64
Resistance is Futile
protrash64's Avatar
.....thats my experience with these trucks, too!! Nice work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-16-2010, 12:33 PM   #10
scotts62
One day...
scotts62's Avatar
Keep up the good work
Scott
93 crew cab build
Project 62
Old 04-19-2010, 12:59 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Another weekend gone by, and some more progress made.
Continued on the stripping, working along the rear fender.
Welding up some holes in the bedrail and starting the prime on the fender
The "bubbled" finish under the rail is some older paint that chem stripper was soaking on.
Old 04-19-2010, 01:02 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Starting to strip the tailgate
CRAP! Hit myself with the grinder while moving it in a tight space
Finished the tailgate
Welded the front bed panel, and then got a little rust hole surprise under the finish.
Old 04-21-2010, 10:13 PM   #13
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
No blood no foul, I guess you can kick it back. I cant tell you how many times I've done that or on the bench grinder with small stuff.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-23-2010, 12:13 AM   #14
Captainfab
60-66 Nut
Good thing you had gloves on....could have been worse.
Your truck's coming along nicely.....keep at it.
Old 04-23-2010, 01:33 AM   #15
62 Bowtie
62 Bowtie's Avatar
Nice work Im gonna start on mine after the summer. Are those the stock tail lights fabbed into the rear quaterpanels?
62 Bowtie is offline   Reply With Quote
Old 04-23-2010, 08:46 AM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
thanks for the comments guys. I ALWAYS wear glove when grinding now; about a 3-4 years ago I had a grinding wheel on it and it slipped when I stepped on the cord. I've got a 1/4" gap in my fingerprints from that one.
62 bowtie - They are LED lens/bulbs. Its the stock size lens, with integrated led's and the stock style plug. I took the reverse lights out, and welded the stock light buckets where the reverse lenses use to mount. I sealed it from the back, and then can screw in the lenses as normal from the front.
Old 04-23-2010, 09:00 AM   #17
DPowers
One foot in front of the other
DPowers's Avatar
Great progress
DPowers is offline   Reply With Quote
Old 04-25-2010, 02:10 AM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Started taking the paint off of the drivers door. Very solid but i did get a few surprises.
Another dent in the same place as the big dent on the passenger door. Its tough to tell what happened, but weird its on the same spot. This side is nearly as bad.
What the heck is this? Looks like a couple of phillips screws that they filled right over. Is this a stock mirror mount or something?
A little bit of crust on the bottom of the door, shouldn't be a tough patch though.
Old 04-25-2010, 11:02 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Sanded down the paint and bodywork on the front fender and got a nice size rust hole. A little bit worse than the other side, but handle-able. There were a couple pinholes a bit higher up too.
Cutting out the rot
The gnarled steel.
And the hole
Cut a patch panel to fit. Luckily the edges were still good on the original steel, so the patch was easy to cut in.
Out with the old and in with the new.
Old 06-18-2010, 07:15 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
its been a while since I posted an update. Alot of progress has been made, and the rest of the photos will come later this weekend.
A couple of changes so far
Fenders are off and all of the stripping has been mostly done. The besides have been stripped now, nice and rust free!
Later this weekend I will have some shots of the finished front filler work, and some progress on patching the lower doors.
Old 06-19-2010, 05:55 PM   #21
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Nice work. Subscribed.
fryer1979 is offline   Reply With Quote
Old 06-22-2010, 11:16 AM   #22
bigblock96
bigblock96's Avatar
digging on those shark shoes Cool
bigblock96 is offline   Reply With Quote
Old 06-22-2010, 12:43 PM   #23
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
haha, thanks man. The shoes are actually painted P52 style, with the mouth on the nosecone, there are kill marks on the sides, and a few various insignias. I think they are from Circa but I can't remember exactly.
Old 06-23-2010, 05:18 PM   #24
REDNOSE65
REDNOSE65's Avatar
Lookin good...
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 06-27-2010, 12:42 PM   #25
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
looks great
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
