in WAY over my head
Re: I'm baack!
Great, so that saves me having to source one, though this one needs rebuilding.
What's the electrical connector for? My objective if I go the carb route is to take the computer out of a role of anything beyond reporting to the gauge cluster what's going on. ah, ok did some digging here. http://www.shopatron.com/products/pr...er=60109/302.0 something like that do the job? this is good because it means I wont need a VSS adapter for the transmission to get the speedo to work, I'll just use the existing harness for the speedo through the factory 700R4. Which leaves me with the tach (read on a camaro form you splice white and pink into bat and tach on an hei distributor) amps (should work w/o any changes) and oil/water which should come from sensors in existing holes in the 350 I'm gonna use. Last edited by DarkFox1; 04-16-2010 at 12:17 PM. |
| Bookmarks |
