Tire problem with coys
im having a difficult time choosing a tire sze for the back. my rear coys have 5 1/2 inch bs and a 285/50/r20 tire is rubbing the inner fender...will a 295/40/r20 tire fit?? i really dont wanna put spacers
Red Chevy's ![]() |
Re: Tire problem with coys
I went with 295-45-20 as I wanted a tire with a nice side wall, zero rubbing on a 20x10 coy wheel with a 5.5 BS....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 04-16-2010 at 05:17 AM. |
my rim goes in 1/4 inch more than your rim so would i be good with a 295/40 tire?
Red Chevy's ![]() |
Man of Mini-Talents
The tire width will vary depending on things like rim width and even brand of tire. What do you have, and will you stay with the same brand of tire?
i have a 20x10 rear tire and im puttin a TOyo proxie st2 tire 295/40/20
Red Chevy's ![]() |
Anyones help is greatly appreciated
Red Chevy's ![]() |
Man of Mini-Talents
According to the TOYO website, the 285/50-R20 is 11.6 inches wide, and the 295/40-R20 is 11.7 inches wide.
The two sizes they recommend for a 10" rim are 275/40R20 and 275/45R20, both 10.8". Figure both of these will get you about 1/2" more clearance than what you currently have. Last edited by Zoomin; 04-15-2010 at 11:52 PM. |
Thanks, i know CrawDadFox ..a member from the board is running 295/40's on his rear coys also. he has the 5.5 BS too soo idk at this point what to stay with
Red Chevy's ![]() |
Man of Mini-Talents
You know that the tires on the wheelsa you have rub, so you need something smaller. What someone else has is immaterial.
Does it rub on one side, lowered with original track bar?
You might want to check if the axle is centered and may have to invest in an adjustable track bar. If you have leaf springs, disregard. |
No the tire i have now is a 285/50 tire and it rub the inner fender bad.. maybe a 40 series will do..my truck is siitin at stock height as well with stock suspension
Red Chevy's ![]() |
I just go back from a trip to the states. I went through Denver and picked up a set of coys. 20x10's for the rear with 5.5 BS. They recommended a 295/45R20 and after mounting the rim on the rear of my leaf sprung GMC and taking some measurements, it looks like that will work no problem. My truck has been lowered about 6 inches in the rear with a flip kit if that makes any difference at all.
1972 GMC LWB, 250, 4sp 2010 GMC Sierra 6.6 CCSB |
ok what was the width in inches for the tire recommended?
Red Chevy's ![]() |
Man of Mini-Talents
Do both rear tires rub?
Are you sure your truck has the stock rear end? |
#15 |
These are the tires i ordered for the rear (295/45):
http://www.tirerack.com/tires/tires....omCompare1=yes They have an overall section width of 11.6 inches which means they will stick out about 0.8 inches from the mounting surface (where the bead sits) on a 10 inch rim. Atleast thats how they explained it to me. Here's a link to your size (285/50) in the same type tire as above: http://www.tirerack.com/tires/tires....omCompare1=yes Says there that yours have a section width of 11.5 inches. So if yours rub, then the size i've ordered wont fit your truck either. I've got the same questions as Zoomin.
#16 |
Just threw on the 20x10 with a 5.5 BS and 295/40 tires with no issues. Have 5" drop as well.
the 285 is the width in millimeters, 25.4 mm in a inch. If you rub with 285's, 295's won't be any better. The next number, i.e. 45, 50, etc is the side wall height as a percentage of the width. side wall = 295 x 45% (or 0.45) Just some usless info in my head that may help you size your tires
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, ![]() 2009 Acura MDX Last edited by hemihead; 04-16-2010 at 04:56 PM. |
#17 |
i do have the original rear end...the 285 tire that was rubbing is on my front coys that have a 5.25 BS..so in other words , i was putting my front wheels in the back to see how much clearance i had
Red Chevy's ![]() |
