Old 05-14-2003, 10:12 PM   #1
C.B.'s 72
part interchange?
First off, great site have found alot of usefull info for my new wheels. My truck is lacking a rear bumper and fan shroud if I were to go to a pull-a-part yard what would be some suitable subs. It has stock radiator and a 350.
Thanks for the help.
C.B.'s 72 is offline   Reply With Quote
Old 05-14-2003, 10:30 PM   #2
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
I'd venture a guess that a rear bumper off a Chevy/GMC stepside up through '87 would work. I doubt the newer fan shrouds would work though - The radiator is taller on the newer trucks.
Nice truck you got there!! Welcome to the board!!
Robert
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 05-14-2003, 10:41 PM   #3
Rod
Welcome to the 67-72 boards.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-14-2003, 10:46 PM   #4
72MARIO
72MARIO's Avatar
67-72 rear bumper chevy or gmc
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-14-2003, 10:50 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Welcome to the board.
You need to look up Wes at Classic Heartbeat Pick up Parts. He is located in Olympia, Wash. (is that close to you?)
Wes normally has tons of used parts and trucks along with great prices on new stuff too. Here is a link to his site. http://classicheartbeat.com.westserver.net/
He is one of the few that I normally recomend...mostly becouse I have not dealt with many places, but he knows his stuff and treats you right.
And that is an awsome looking truck...whats the details on it?
Old 05-14-2003, 11:02 PM   #6
Lightspeed
while we're on the subject will a brake booster and master cylinder off of an 85 pickup work on a 71 pickup?
Lightspeed is offline   Reply With Quote
Old 05-14-2003, 11:06 PM   #7
C.B.'s 72
Thanks for the compliments. The details aren't alot.I bought it a month ago for 4k it has had some work done rebuilt 350/350, guages, 12 bolt rear 3:73 gears newer paint. Have lots of plans but as seems to be a common theme (no money and less time). Maybe when I'm done in the Air Force I'll have time and money to fix it up right!
Old 05-14-2003, 11:23 PM   #8
bpmcgee
bpmcgee's Avatar
Lightspeed,
My understanding is that the primary concern with master cylinders is that you need the same configuration of brakes or you'll run into problems.
Drum brakes require a great deal more pressure to work than disk, so if you used a drum-rear M/C with disk-rear brakes, you'd have your back brakes locking up way too fast. The opposite would also be true.
Brian
bpmcgee is offline   Reply With Quote
Old 05-14-2003, 11:32 PM   #9
Lightspeed
well i have a disc/drum setup on my truck and im guessing that the 85 would be the same. im more concerned about it actually bolting up than anything else.
Old 05-14-2003, 11:52 PM   #10
Blue68
Blue68's Avatar
On the fan shroud, go with the original equipment. Small block ones are available on the parts board on occasion. Don't get in a hurry, you'll be fine without it in Spokane for a couple more months. Problem with finding a pull a part might be bolting it up to the radiator more than anything. Post a request for a shroud to the parts board and someone will likely come the the rescue.
One the booster items, you probably can use the master cylinder and prop valve and be okay. I've seen newer ones used, and it will need to be disc/drum components (don't thing there was any other options in '85, no ABS yet on the rears). I doubt the bracketry will fit nor the brake pedal angles are the same. Most if not all of the original components are still availble from supporting distributors as well as your local parts house. Someone will have a shot cab that you can buy the booster bracket an rod from on this site too I would imagine.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 05-14-2003, 11:53 PM   #11
Blue68
Blue68's Avatar
BTW, awsome looking truck for 4k.
I have two brothers that live in Seattle, thus I have picture of my daughter with clouds very similar to the ones in your picture.
Old 05-15-2003, 03:48 AM   #12
cheyenneman
Hey I live here in Spokane and I might have a used fan shroud for you. I will look tomarrow and see what I got.
cheyenneman is offline   Reply With Quote
Old 05-15-2003, 05:12 AM   #13
Welcome to the board from south Mississippi.
Old 05-15-2003, 05:58 AM   #14
meathead95
computer illiterate
meathead95's Avatar
welcome from nashville
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-15-2003, 08:10 AM   #15
Blue Beard
Blue Beard's Avatar
Welcome from Southern Washington State..............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-15-2003, 08:25 AM   #16
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
For the cost of a new repro bumper, I'd definetly go that route over used. Especially if going with a chrome one.
A truck worth 4K deserves a new bumper!
For the fan shroud, search the junkyards. I found mine that way. I paid $3.00 for it! :p
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-15-2003, 08:34 AM   #17
griesel72
griesel72's Avatar
welcome from kansas
david
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 05-15-2003, 12:14 PM   #18
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I have a painted rear step bumber I would sell. Shipping might not be worth it though.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-15-2003, 12:50 PM   #19
Linus0014
Guest
Posts: n/a
Welcome from So Cal
Benny
