Old 04-18-2010, 01:19 PM   #1
tim21391
tim21391's Avatar
distributor cap problem i think?
popped cap off to check the cap to see if thats why i cant go over 70 on highway but in town driving is fine.. then i seen on my msd cap that there is a thin trace at the back of the cap thats a perfect ring around it maybe like 1/2 inch from the 4 holding clamps.. so i just wiped it off and called it good.. then i popped my accel hei super pack coil or whatever its called and you know that little rubber circle with the spring and the button lookin thing? that melted a little bit of that plastic stuff on my coil and made the connecting point kinda bronze color.. so i think i found my problem.. i assume thats it?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-18-2010, 08:41 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: distributor cap problem i think?
I am not sure your cap is keeping you from going over 70 mph, but from what you described I sure would replace it.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
