Robert Olson Transport
![]() Join Date: Oct 2002
What did you get done 4/18/10 weekend after tax day edition
i didnt get much done at all ive had so much to do here you all?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: What did you get done 4/18/10 weekend after tax day edition
I got the hood put on, and I worked all weekend!!! I'll have two days off to get some stuff done.
Fired up the Kiowa took off the trash and fixd the speedometer.
Getting Old; Going Broke
Got a piece of dash spliced in where some idiot had hacked it for an aftermarket radio. Got a factory radio wired up and working. Swapped out cluster panel and wired a factory clock. Cleaned a used cluster bezel up, took all the peel and stick brushed aluminum off.
Basically got the interior all put back together and wanted to drive it home. Had put a piece of cardboard under the engine area to make sure we stopped the oil leak (sending unit). It looked nice and dry under there. But.... under the rear end was a huge puddle... Seems my pinion seal is shot. Guess what I'm doing next weekend.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
washed the stepside ... put new real trans mount in .. worked on my daughters front porch .... not time to rest some before work tomorrow
2011 silverado 2500hd ext. cab 6.0 2007 tahoe lt 2004 harley-davidson superglide 1982 chevrolet c10 stepside 2 wheeldrive..current project |
I really hate wet sanding!
![]() Join Date: Dec 2008
Okay, I completely remove the entire front and rear suspension from my 80 donor truck. Cleaned the suspension parts. Fixed two smallish dents in my hood, primered the hood and front valance, and then blocked out the hood. Then went home and mowed the yard, trimmed a tree, and burnt the trimmings. That was on Saturday, then today wet sanded the hood and front valance, then shot them body color, base coat/ clear coat paint. Washed the front clip of my truck and washed and cleaned the engine and engine bay. Then went mushroom hunting, only found about a dozen, the biggest being about 2" tall. Then I had to be a work at 3 pm.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
Old Heap Driver
Just got home from Super Chevy-Petersburg. Had a blast, spent too much money, made new friends, won runner-up in my class!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
The One And Only !!!
Snagged another award with the 97 yesterday....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Navy Radioman Veteran
Drove back from Gatlinburg (27th Anniversary Trip) yesterday after checking out 3 days of rods in Pigeon Forge, TN. The 87 is at the body shop getting undercoated and paint touched up. Should be back home tomorrow.
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 04-18-2010 at 10:31 PM. |
Rebuilt the quadrajet and replaced all the vacuum lines.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
On Sat, my dad and I went and picked up a hood for his '66 C-10. Today (Sun) I spent most of the day tinkering with my Blazer. Pulled the rear bumper, the rear hitch setup, and then dropped the gas tank to replace the leaking fuel hoses. Ended up cleaning the tank and painting it, same deal for the hitch and the rear frame rails and bumper brackets. Also repainted the bumper filler and kinda-sorta straightened some kinks in the bumper. ...Now if only the rest of the Blazer looked that good
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
celebrated 40th anniversary
Old Heap Driver
Slugish
![]() Join Date: Jan 2005
Congrats on the runner up Brian . really wanted to come , but it didnt work out . Many other 73-87's there ? probably like other shows mainly 67-72's & older .
#15 |
Squarebody Aficionado
Well I got nothing truck related this weekend I was finally blessed with the birth of my son. I did order some billet pedals that should be waiting for me when I get home.
#16 |
finally painted the 87!
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
#17 |
Welded up my lower frame mounts, built and welded up my lower rear links and tacked my lower axle mounts. Now I need to focus on the bridges, shockwave mounts and upper links.
#18 |
OL BLUU
![]() Join Date: Mar 2004
Picked up some 275/60's off of CL for the Blazer and had them installed on the rear... deciding if I wanna do the front with 275/60's as well. Decisions desicions!
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
#19 |
BMW & ASE Master Certified
made a 3d rendering of my rear disc brackets...
http://img528.imageshack.us/img528/6679/70476241.png clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#20 |
those are almost looking over engineered. haha
for me... not very much done to the truck, pulled a couple things out of the blazer, founds out that i had the wrong valve seals so the motor is on a stand still... as for the bike... for some new forks for it (feels 100X better now), and put in a order for a new helmet, etc.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#21 |
TURNED THIS...
INTO THIS... It's my dad's Elky. now it's his turn to help ME work on my square body |
#22 |
OutOfMyMind & I'llNeverKnowWhy
Sprayed on some engine degreaser and carb cleaner. Still dirty tho
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
#23 | |
Old Heap Driver
It looked to me that most everything doubled from Saturday to Sunday, show cars/trucks, and swap meet vendors. I'm sure the rain Saturday morning hurt all aspects of the show. I know I didn't enjoy driving a highly detailed truck in 2 hours of steady rain Saturday morning. ![]()
#24 |
Low & Fast!
Well, last week went very well! We had 2 1/2 weeks before we close on the new house and have not sold the old one yet, but someone is now buying it and closing the same day as the new one. WOW! Some times things are just mint to be. So only one house payments!
![]() Pic of my new bar in the house! ![]()
#25 |
>130dB Moderator
I worked my butt off Saturday and took the day off and BBQ'd with the g/f's family Sunday. Not doing anything truck related until I save up some serious $$$
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
